Panasonic TX-P42G10B 5 blinks
    I decided to get a G10... saw one cheap near me and snapped it up. In great condition. I won't break the panel on this!!
    TX-P42G10B
    Has a TNPA4844 SC board
    Seeing 5 blinks I was suspecting panel. Thought it was worth a risk anyway. Turns out SC board is dead short zero ohms across Vsus. I presume this triggers the 5 blinks fault. Unplugging SC gives expected 7 blinks.
    Buffer boards test OK no shorts across FGND to VSCAN or to panel ribbons.
    Found a good collection of IGBTs dead short. Q604 is OK so it's a Vsus short versus other faults which cause 7 blinks. I guess next step is to replace IGBTs and possibly the driver IC?
    Any good sources for IGBTs - utsource I presume?
    Re: Panasonic TX-P42G10B 5 blinks
    Tests: 0.0 ohm at Vsus
    IGBTs G-C-E short:
    Q621/Q623, Q422/Q423/Q424 (G-C/G-E leaky - 120 ohms), Q661
    IGBTs only G-C short (G-C/G-E open):
    Q402/Q403/Q404
    FET shorted D-S, leaky D-G:
    Q660
    • tw2005
      • Oct 2011
      • 6458
      All chinese to me Tom
        IC16771 = no shorts
        IC16464 = untested, but if Vreg & driver OK should be fine
        IC16465 = as above
        IC16773 = no shorts Vcc/GND/out any way
        Q16701 = no shorts, seems OK
        Q16702 = no shorts, seems OK
        D16865 = need to pull IGBTs to be sure if good/bad
        Rough translation seems to indicate that if the FETs are bad above components should be tested and replaced.
        I know you have experience with logic buffer ICs being bad, did you usually find them shorted? I'm getting kohm+ for all of them. Same for the Vregs.
        I think I'm going to pull all the FETs/IGBTs, jumper SC50 & test with a scope for drive waveforms. See what it looks like then see if I need to do any of the small logic. Even the gate resistors for the IGBTs test OK.
        • tw2005
          • Oct 2011
          • 6458
          Originally posted by tom66
          IC16771 = no shorts
          IC16465 = as above
          If you're talking about the octal buffers from sc20 I've had one short but any one of the buffer ccts within could be damage which i don't think you could prove with a meter. Worst case there I think it may simply not work and throw a sos7 which i've had one do.
          I'd be more focussed on those schmitt inverters and to be honest easy and cheap to get especially if you use a texas instruments chip which they have a direct replacement for. If they're bad I'd expect transistors to short out again.
            I think the best way is to see if the IGBT gate waveforms are OK. Then I can go ahead with replacing the driver ICs & logic if necessary.
            Which Schmitt inverters -- you talking about the ones near the IGBT drivers? For those I can check input & output and see how it looks.
            Got any good sources for the required IGBTs/FETs? UTSOURCE I presume?
            • tw2005
              • Oct 2011
              • 6458
              UTSOURCE is all I have used with the 5081 boards and had no issues. Prices have dropped quite a bit not sure about the ones on your board but given the time it takes for these to arrive I'd get extras in case first attempt fails.
              EIther that or see if there are any kits but usually more expensive. iC773,464,465
              mentioned in the guide Q16701、Q16702、D16865、
              IC16771、IC16464、IC16465、IC16773
              Marked HA if they're the same as the 5081
                Thanks to tw2005's keen eye, an SC board was spotted on eBay Poland. £33 later, the TV is working great!
                • tw2005
                  • Oct 2011
                  • 6458
                  Hell, that was a coincidence, I was just digging this up to see where you got with the repair when I remembered the tip.
                  Sweet. glad it worked out, bonus - you still have a SC repair project
                    17,007 hours and 3,000 power cycles - panel is absolutely PERFECT with no burn in at all! And it's SO BRIGHT!!! Brighter than my Kuro, PZ80 & D450-3D.
                    • tw2005
                      • Oct 2011
                      • 6458
                      Pretty sure this has been asked before but what is the highest hrs you've seen on a panasonic?
                        14,500 hours on a PZ80, this is a new record. I have never seen burn in on a Panasonic plasma panel, having done 8 now. Yet I've seen plenty of LG & Samsung panels with burn in and less than 10,000 hours.
                        Man, if it were only Panny making plasmas, it'd have a far better rep as a technology!
                        • tw2005
                          • Oct 2011
                          • 6458
                          Well, I hope mine keeps running well beyond. they're great panels. I'm going to keep my spare 42X20 and 46PZ now that there's no more Plasmas built by panasonic.
                            Yep, with Sammy leaving the biz this year, and LG likely to follow suit soon, I might have to stop fixing plasmas - no good if I can't sell them!
                            • tw2005
                              • Oct 2011
                              • 6458
                              Really, yeah, LCD posts are higher than plasma and over here nationwide on Ebay, very poor for picking up decent stuff but see a few PZ series popup still.
                                Eh, this one was VERY cheap on eBay so I nabbed it quick!
                                • Andre Gilbert
                                  by Andre Gilbert
                                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                  11-20-2024, 08:52 PM
                                • jm1234
                                  Panasonic plasma TX-P42ST50 - 6 blinks
                                  by jm1234
                                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                  I checked that board for any obvious faults...
                                  05-22-2024, 06:59 AM
                                • Alicat
                                  Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                  by Alicat
                                  Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                  Model number is TH-50PZ85U
                                  Power comes on and the red power light stays on solid.
                                  Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                  I also hear a few clicks.
                                  I also think my parents said there was a thunderstorm and the TV failed after that.
                                  Section 6 in the service manual talks about power and no screen,...
                                  10-30-2024, 10:09 AM
                                • Buzztv
                                  Panasonic TC-P42S60 Plasma,how to check Vsus
                                  by Buzztv
                                  This is my first post in attempting to keep my beloved 2013 Panasonic plasma tv going.
                                  About 6 weeks ago the tv was turned on but then immediately shut off. There was no recent power surge or popping noise or any other symptom.
                                  I checked all of the obvious things and decided to try a replacement power supply board (PSS in Panasonic lingo).
                                  I would like to check the Vsus but this is one of the final models and at that point Panasonic did not indicate the Vsus and Vad voltages inside the chassis. It looks like they were discouraging people from making adjustments....
                                  10-27-2019, 01:24 PM
                                • CrewmanRedShirt
                                  Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                  by CrewmanRedShirt
                                  Hello all,
                                  As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                  07-13-2024, 11:02 AM
