Sanyo DP50747-00 50" Plasma with Samsung innards
  • Howie
    • Dec 2004
    • 31
    Bought this unit to see if it could be repaired.
    TV power led comes on with a clicking sound, stays about 3 seconds and shuts off with a clicking sound. Nothing on the screen happens during this cycle.
    Knowing most issues are PS caps I took the back panel off and to my surprise none of the caps looked bad. I went ahead and replaced all the output caps, even the small ones, with no change.
    I disconnected the Y & X boards and tried power with no change.
    I disconnected everything except the main control board with no change.
    I haven't checked the output voltages on the PS yet, but wanted to have an opinion.
    Wouldn't this suggest a PS issue or main board issue if the other boards are disconnected yet no difference in problem?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sanyo DP50747-00 50" Plasma with Samsung innards
    Yes. Some manufacturers label the voltages on the output connectors of the power supply. Have you verified those?
    PlainBill
    • Howie
      • Dec 2004
      • 31
      I checked the fuses and the fuse at F8201 on the power supply was blown and continues to blow them when the power button is pressed. Google search brought up that this usually means a diode at the D8302 location will be shorted as well. It continued on that these were replaced, but the TV would still not come on and they suspected the "MR4030 Partial Resonance Power Supply IC Module Supporting Standby Mode Operation" at the U8301 location.
      • Howie
        • Dec 2004
        • 31
        OK, I checked that diode and it has a big hole in the top and is blown. Now I cant make out the part number that was on there. Anyone have a service manual? Anyone think that it would be the MR4030 IC voltage regulator that was at fault and started the chain reaction?
          What does the diode look like? It may be possible to replace it with any suitable diode based on where it sits in the power supply.
          • Howie
            • Dec 2004
            • 31
            From what I can research online its a UF4007 Diode Circuit Protector
            They are two diode's right behind the small blue cap in the area I put a square around & the arrow is pointing at.
            • SegueTx
              • Sep 2011
              • 1
              I'm having the same problems with a Sanyo (Samsung guts) PS-50 W3-STD (assuming same power pcb is being used as in the DP50747). First the F8201 pops, and I'm noting that U8301 (B0883/MR4030 Transistor) is blown, along with a partial trace on the back of the board. The trace repair is no problem, nor is replacing U8301, skills wise on my part. My biggest question is this: If I replace U8301, F8201, and repair the trace, "should" it work when done? (the diode mentioned by others seems fine). Or should I just spend the $C note and pickup a whole new power pcb? This Tv is 3yrs, 3mos old and was given to me on a "get it out of here and you can have it" basis, so anything I spend on parts is my only investment. I've been into electronics for over 30 years, 16+ as a digital systems specialist (color and black/white electrostatic imaging equipment), so the skills are there to do the work. Not having schematics at hand is my main handicap here. There's always that debate for me, replace a $3 component and take a chance, or just go ahead and toss a new assembly at it (at 3x + the cost). Any suggestions appreciated!
              Chris in Central Texas
              • hijodalgo
                • Jan 2011
                • 35
                what's the board number??does it begins with BN44-****??let me know,because I have some schematics for power board from samsung..BN44-00159A,BN44-00161A,BN44-00162A,BN44-00183A,BN44-00193A,BN44-00194A,etc..
                • Redion
                  • Nov 2010
                  • 59
                  I wonder if replacing MR4030 solved the problem?
                  I have exactly same PSU with exactly same problem!
                  Would be nice to know if OP got it working...
                  • Redion
                    • Nov 2010
                    • 59
                    Hi every one, so here is my conclusion:
                    Replacing MR4030 and the little diode that shorted out beside it did the trick.
                    TV powered ON and works without any problems!
                      09-07-2024, 05:50 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
                      Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                      This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 06:20 PM
