Component blow up, Asus GL704
Re: Component blow up, Asus GL704
Okay, at First thank you for the more detailed View now.
Where should i begin...
Obviously the Laptop didn't start at all. RAM, CPU and GPU voltages are Missing.
But i See another Problem with the Coils you forgot in the First Pic. I believe there is an RTX2070 soldered? In this Case we could tolerate the Low Reading at the GPU Core Coils but Not the Low Resistance to ground of the four upper coils which Points to the CPU Core (in my opinion).
How Low exactly is the Résistance Reading when you short your probes directly to each other?
This seems to be a Very expensive Board, so i'm a little Bit afraid to Help troubleshooting. Usually i would suggest to lift all four upper coils, then Check on which Side is the short. If the short is on the CPU-side inject 1V 2A and Look whether the Voltage Drops. But as i Said i am a little afraid. For me it is a clear Short at VCore but Maybe Someone Else Would confirm this is a normal Reading...
Which Type of CPU and GPU exactly are soldered there?
I have another Question: Shouldn't this Laptop still be in warranty?Comment
Thx for your reply I really appreciate your time helping me.Okay, at First thank you for the more detailed View now.
This laptop is 8750h 2070RTX.
My multimeter shows 00.0 ohm when probes are shorted to each other.
This board isnt under warranty anymore.
Edit: after reading your reply again and again, i did a new test and here the result:
This Looks much Better now. Good, you double-checked your measurements.
I have an Board with GTX1080 Here which still (somehow) works and reads Only 0.3 Ohms to ground, so should be fine. Resistance of CPU Core is high enough to Not suspect an issue there anymore.
So what next? You should Check whether the Voltage at the Power Button (or the corresponding Pin at the connector) has 3V present and Drops to 0V when pressed.Last edited by Sephir0th; 04-24-2021, 04:47 PM.Comment
Done, found the corresponding pin and it drops to 0v when pressedThis Looks much Better now. Good, you double-checked your measurements.
Ps: I updated the pic with where the 19v arrive at cpu coil level.. it drops to 0 after the little mosfet
Okay, that's fine but now the really hard Part of the repair begins: The search for Missing Logic Signals. This is already hard with Schematics but even harder without...
*** Edit: forget about the EC. It's a BGA one, it seems from ITE. But you could Check whether it is getting warm or hot when powered. It's located below the SSD. You should Remove the SSD anyway permanently to exclude an issue from there.***
Share also a clear Pic of the Region where the Coil with 68.3 Ohms measured, both Sides of the Mainboard. I want to know where the RAM Controller is soldered.
Did you Ever Tried to start the Board without RAM? Or Tried with another known working RAM? And of course you are working With a known good Adapter of correct wattage?Last edited by Sephir0th; 04-25-2021, 03:16 AM.Comment
Yeah i did test with other working ram,Okay, that's fine but now the really hard Part of the repair begins: The search for Missing Logic Signals. This is already hard with Schematics but even harder without...
** Edit: forget about the EC. It's a BGA one, it seems from ITE. But you could Check whether it is getting warm or hot **
For EC ITE IT 8291E120A on the otherside:
Ram Coil region:
Otherside of motherboard ram region:
Is this the BGA ? :
Cant really feel if its warm or not.Last edited by ZoOLf; 04-25-2021, 03:23 AM.Comment
No, Not this Big one i mean the Second EC directly below the SSD. It's black, much smaller, has No Pins, and should be also from ITE. Check both ECs whether they're getting warm or hot.
Meanwhile i'll Check the Datasheet of the controller you found around RAM Area.Comment
Ahh i see, this one:
IT8225VG 128
Its not getting warm or hot...Comment
Okay, Back to the RAM-Controller.
Check carefully Voltage of the Blue circled Points before and after Power Button pressed. Take also notice of Something Happening for an blink of an eye right after pressing. Take Care to Not accidently short Something. Additionally Check Resistance to ground of the Blue circled Points with all Power removed.
Actually i'm Not Sure how to Check the ECs without Schematics so my Help could come to an end soon...Comment
Thx for your timeOkay, Back to the RAM-Controller.
Here the reading
Pls note that nothing happens when i press power button
Edit: dono if this is important but before the laptop was starting automatically when plugin the charger with battery disconnectedLast edited by ZoOLf; 04-25-2021, 07:48 AM.Comment
Regarding the Results, your RAM-Controller Receives Just No Logic-Signal after pressing the Power Button.
In my opinion this Points to an Issue in the area of the EC. There is still a small Chance It's an BIOS issue, so you could get an cheap CH341A Programmer and try to reprogram the BIOS of the Board with a known working dump... Who Knows...
I'll try to find Out in which way both ECs are working on your BoardComment
I really appreciate your help and the time spent with me,Regarding the Results, your RAM-Controller Receives Just No Logic-Signal after pressing the Power Button.
I already ordered an CH341A, I just thought the problem cant be related to the bios chip
Could the bios be resposible for the charge management? Bcz when the battery is connected the led dont turn on.Comment
Hard to Tell why the Board with Adapter Only powered on before and now no reaction anymore.
I don't have a good answer for this behaviour but it could be that there are at least two issues Maybe three, because it seems there is additionally an issue at the Charging Circuit and for this reason the battery isn't Charging anymore.
It could also be the Case that all Points to the EC, because usually it communicates with the Battery via clock and Data Signals.
But this is Only guessing. Better to have facts, but hard to get some without Schematics or Datasheet.
However even with an issue at Charging Circuit, the Board should be able to start. For this reason i want to troubleshoot this behaviour first and If we are able to solve this, then we can Take a closer Look to the "smaller" issues, Like Charging Circuit and LVDS-Connector.Last edited by Sephir0th; 04-25-2021, 10:08 AM.Comment
Much appreciate my friend.
I will wait for the CH341A to arrive and test it.
Just another noob question: i searched for the bios of this laptop found one: bios +EC, how to flash the EC file? And can i just flash that bios.bin to chip directly to the Chip with CH341A?Comment
Right, you can reprogram the MAIN BIOS easily by flashing the .bin with the Software Like "Neoprogrammer". It is recommended to Remove the SPI FLASH from the MB and solder it to the included Mini-PCB and of course, make an Backup of your existing dump.
With the EC it wouldn't be an easy Task Like this. You need an Special Programmer Like Vertyanov Jig or SVOD to Programm it e.g. via the Keyboard Connector. However, it is often possible to buy such ECs preprogrammed from some merchants so you Maybe don't have to buy this Tools. Of course Anyone has to replace the EC, which is a small BGA (the one which needs Programming ist the one below the SSD). It needs some experience to solder it without issues.
So try the MAIN BIOS First. If this don't solve the issue we can brainstorming about what doing next.Last edited by Sephir0th; 04-25-2021, 11:14 AM.Comment
Hi I came back after a long time, with some updates:Right, you can reprogram the MAIN BIOS easily by flashing the .bin with the Software Like "Neoprogrammer". It is recommended to Remove the SPI FLASH from the MB and solder it to the included Mini-PCB and of course, make an Backup of your existing dump.
1- so first I received the ferrit 3A and solder it in its place, now i have the 19v reaching the LVDS connector,
2- now when i connect the battery and the AC adapter, I have charging led lighting Orange (before it stayed off until i disconnect the battery) and it turned white after some times (which means the battery is fully charged)
3- I did flash the bios chip with CH341a clip, i flashed it soldered on the MB , no luck, the laptop stays dead.(do I need to desolder it and flash again?)
any other idea?Comment
also , if i hold power button for long time when battery and charger plugged, the full charger indicator turns off,
Edit: another thing, when i said earlier that im missing 5v when on battery, it needed a simple power button press to get it on rail, but the laptop still wont power on. does it need the fans plugged ? sort of protections?
im really need ideas and help
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:00 AM
- Loading...
- No more items.
