Lenovo Yoga 730-15IKB dump
  • CraterM
    • Mar 2018
    • 178
    • Moldova
    Hi, does anyone have a dump for Lenovo Yoga 730-15IKB
    TNX
  • Ghamidi
    • Mar 2020
    • 303
    • France
    Re: Lenovo Yoga 730-15IKB dump
    Originally posted by craterm
    hi, does anyone have a dump for lenovo yoga 730-15ikb
    tnx
    hi try....
      • 21040
      TNX
      Post your bios backup, and machine Type .
      • CraterM
        • Mar 2018
        • 178
        • Moldova
        Originally posted by smdflea
        post your bios backup, and machine type .
        81ou
        • CraterM
          • Mar 2018
          • 178
          • Moldova
          Originally posted by Ghamidi
          hi try....
          Power ON, but no display
          • fire1234
            • Dec 2017
            • 77
            • Poland
            81ou
            hi try.... Your serial numbers and key copied
            • Ghamidi
              • Mar 2020
              • 303
              • France
              TNX
              try this bios extracted from officiel site
              • Ghamidi
                • Mar 2020
                • 303
                • France
                I think it's the same of member fire1234
                • fire1234
                  • Dec 2017
                  • 77
                  • Poland
                  Exactly the same bios version , I also copied the serial numbers and windows key from the bios copy.
                  • Ghamidi
                    • Mar 2020
                    • 303
                    • France
                    great job
                    • CraterM
                      • Mar 2018
                      • 178
                      • Moldova
                      Workkkkkk great, thank you!!!!!!
                      • mferna14
                        • Jun 2018
                        • 1026
                        Hi, can some clean my Lenovo Yoga 730-15IKB laptop dump. As of now "NO DISPLAY" but all the voltages seem to be fine & the fan spins too. The startup even seems to be normal. I have uploaded the Original BIOS Dump, kindly clean. The machine Model Name 81CU & Serial # is MP1PEERG.. Thanks in advance
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          Become a Badcaps supporter
                          Thanks to all supporters.​
                          • mferna14
                            • Jun 2018
                            • 1026
                            Thank you so very much, will try it tomorrow first thing in the morning... Do you know there is another 8MB Bios on the motherboard., what is this for???
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              There is no second 8MB bios chip, maybe you are talking about the EC chip, but it's not 8MB.
                              • mferna14
                                • Jun 2018
                                • 1026
                                Pls. Check this photo, it clearly show another BIOS chip, it's surely not the EC chip. Now for the BIOS I re-programmed, but still NO DISPLAY, now I see that the Amp meter is stuck at 0.95 amps & in the start goes up & down & then stays at 0.95 amp., where as in the older BIOS it was just stuck at 0.45 amp. I think your BIOS update needs a little more touch up, all might work again.. Thanks in advance.
                                  • 21040
                                  Look at the traces ,see where they`re going,straight to the TPS65988 chip. USB-C firmware .Schematic https://www.badcaps.net/forum/showthread.php?p=1069721
                                  The bios posted by Vesko is a virgin one.
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    A little more touch up? Give me a break will you It's a virgin update straight from the Lenovo web update page, with your DMI and Windows key added to it, so I can't make any better "touch up" upgrade on top of the factory build.
                                    SMDFlea is right, this is a USB-C firmware chip, and besides I think it's not 8MB, I can't see the marking but usually USB-C firmware is not so big, I don't know why you think it's 8MB, see what are the markings on the chip, and you'll find exactly what is the capacity.
                                    Ediit:
                                    Yes it is, thank you - virgin bios with clean ME firmware. The problem if the board doesn't turn on, can not be bios related.
                                    • mferna14
                                      • Jun 2018
                                      • 1026
                                      Ok, the marking on the Winbond Chip is 25Q80DVSIG.. Good is that I got the display with your 100% working BIOS. Actually the PCIe SSD Card is shorted this is why I guess the BIOS dump got corrupted. Removed it from the slot & all worked fine. But now again it got dead as soon as I put in this card again, but tomorrow will figure out what's the problem. Thanks for all the help.
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        Yes, just as I guessed.
                                        80 in the marking of the chip does not mean 8.0MB
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 05:00 AM
                                          Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 6 boardview and X1 Yoga Gen 6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                          Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
