Where to buy 100% true Rubycon capacitor
  • liukuohao
    • Oct 2013
    • 63
    • Malaysia
    Re: Where to buy 100% true Rubycon capacitor
    Originally posted by c_hegge
    What kit did you get? None one kit costs more than around $80 (the PSU repair value pack).
    Yes, preventative recapping is always a good idea. Usually, I try to avoid getting hardware with junk caps, but if I do, then I often recap it before it fails.
    @C_hegge
    Actually, I bought the Asus A7N8X capacitor kit, for my recap project.
    Yes, you are right it does not cost USD$80, but since I based at overseas,
    after doing the currency conversion, I forked out approx. 100 dollars in
    my own country currency.
    Hopefully, those caps will revive my A7N8X-Deluxe Motherboard.
    I am just having this problem, it can boot up but after about a few seconds,
    the motherboard just stops, and I unplug & replug the power cable at my
    PSU, in order to boot the motherboard up and run POST, that is the only
    way. But even though, it is doing POST, after a few seconds,
    it will completely shut down after running about 1 mins top.
    I have tested the motherboard using 2 different make of PSU,
    problem. I don't think the PSUs are faulty.
    Thank you
    • mariushm
      • May 2011
      • 3799
      Just be extra careful with how you install the capacitors, because Asus and Asrock use the negative strip for the positive side of the capacitor on the motherboard.
      I mean the negative strips will not match, like in this picture:
      • liukuohao
        • Oct 2013
        • 63
        • Malaysia
        @mariushm
        Thanks for the reminder, I notice about the labellings on the Asus and Asrock
        motherboard.
        That is by convention, the half circle that is completed filled, should be
        NEGATIVE logically, following modern capacitors has its "-" negative side
        completely filled.
        However, that is totally the opposite in Asus and Asrock motherboards, the
        half circle that is completed filled is identify as "+" positive side.
        Rest assure that I will use a fine tip marker pen, label the motherboard
        surface as which sides are "+" and "-" first before recapping the capacitors.
        Thank you.
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • Agent24
          Dick Smith Q-1760 linear power supply filter capacitor question
          by Agent24
          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
          It has at least one problem.
          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
          I have already ordered a replacement potentiometer, so that's not an issue.
          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
          All are CapXon...
          10-21-2025, 05:39 PM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • chth96
          Should I replace polymer capacitor?
          by chth96
          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
          Is this ESR value of polymer capacitor correct?...
          11-18-2022, 04:22 AM
