Troubleshooting ASUS A8N-VM CSM
  • dcatoni
    • Jan 2011
    • 5
    My A8N-VM CSM ran almost 24/7 for four years and was the most stable computer I've ever had. Then it started freezing up all the time and shutting down programs. I ran memory tests and processor tests multiple times which showed no errors. I also swapped memory to be sure it wasn't that. I reinstalled Windows which didn't help. I thought for sure it would be bad caps, but I just built the Blue ESR meter and all the caps tested good. Visually everything looks fine on the board, nothing burnt or swollen. What should I do next?
    Dante
    Rhode Island
  • mockingbird
    • Dec 2008
    • 5488
    Re: Troubleshooting ASUS A8N-VM CSM
    You can't test caps in circuit.
    I repaired an A8N, and around the VRM was 8mm UCC KZGs (They are brown caps with a honeycomb type vent). Chances are you have those caps, and if you do, you'll need to replace them with something else. I used Nichicon HM.
    If you show us a good picture of your board, someone can tell you what needs to be changed.
    • dcatoni
      • Jan 2011
      • 5
      This image looks better than I could take myself. I was thinking I have to change all the 8mm caps on this board and that it would probably be OK to leave the nine 6mm 100μF caps alone. Is that correct? I really appreciate the help.
      Dante
      • mockingbird
        • Dec 2008
        • 5488
        You should change every cap on that motherboard. It looks like they're all KZG.
        Everything except for the really tiny ones without a vent, that is.
        My guess is you have a combination of:
        16V 1000uF
        6.3V 1500uF
        6.3V 820uF
        16V 470uF.
        All 8mm.
        1) https://www.badcaps.net/store/produc...products_id=69
        2) https://www.badcaps.net/store/produc...roducts_id=136
        3) https://www.badcaps.net/store/produc...products_id=71
        4) https://www.badcaps.net/store/produc...products_id=73
        • dcatoni
          • Jan 2011
          • 5
          I just started desoldering. I took out the two next to the processor near the edge of the board, they both tested 0.01
          How many should I remove before concluding that the caps might still be good?
          • mockingbird
            • Dec 2008
            • 5488
            8mm KZGs:
            Originally posted by PCBONEZ
            UG!
            FJ, FL, WGL2, NRSJ -- [.016][.013]
            MBZ, HM, WG, GD, KZG, NRSK -- [.018-.019][.013]
            KZG, ZLG -- [.020-.021][.013-.014]
            I would preemptively recap them even if they are good.
            • dcatoni
              • Jan 2011
              • 5
              I just ordered all 42 caps, but I'll test the board before changing the 100μF ones. These things don't like to come out of the board.
              Dante
              • retiredcaps
                • Apr 2010
                • 9271
                Did you check your power supply? It may have bad caps inside?
                --- begin sig file ---
                --- end sig file ---
                • mockingbird
                  • Dec 2008
                  • 5488
                  I only counted 31 that warrant replacement. You're really wasting your time replacing the small ones, as they're probably a reliable series and you risk lifting the traces whenr eplacing them so the less you meddle, the better.
                  Yes, you most certainly should crack that thing open.
                  • dcatoni
                    • Jan 2011
                    • 5
                    I took this board out of service over a year ago. My new one has been running on the same power supply since then, so I'm sure it's fine. I've checked the voltages too, because it makes a high pitched whine. I had the first one replaced under warranty because of this, but the second one has been doing it for 5 years. It's a common problem in the Antec 300.
                    I want to use this old board for a low budget HTPC build since I have the memory and CPU.
                    OK, I won't change the 100s. I like to build electronics projects so I'll use them for something. I've just never worked on a mobo before.
