Hi guys,
I have a burned Bestec power supply, the problem was at the IC 8, it shorted due to humidity and burned itself, I was able to see the inscription on top of it and it says, A 635 M, not very sure about the M, and looking at a past thread I saw that someone said that this power supplies had the A6351 pwr chip, so i figured it was the one it burned out on my power supply. But after I reviewed the datasheet I saw that pin 1 is Source, pin 2 is GND, and pin 3 is Vin. Knowing that, before i solder it i saw that on the track where they are supposed to be solder is a continuos one. what I mean is that if i solder them pin 1, 2 and 3 will be shorted, pin 4 is separetly. So this is where I ask you guys, would it be that the chip I bought is not the right one? not the A6351, or the track is bad due the burn out?. Cause it doesnt make sence to me that the pins 1,2, and 3 get welded tougether. Thats why I was looking for a Diagram for the power supply but I just dont find it anywhere. Any suggestions?
By the way, english is not my native tounge so please bare with me if I dont express myself correctly or with the proper terminology.
Thanks,
Paul
Thanks,
Paul
HR circuit Diagram
