Re: Panasonic plasma TC-P42G25 one LED blink, no power
One thing I think is worth doing on these is putting a series light bulb in line with the Vsus line. Start with a 60W bulb. Ideally 230V rated or you can use two 115V n series..This limits any potential fault current. On a dim image the TV will work with the lightbulb in series and should glow slightly. If a bright image appears it might go 6/7 blink if so you can up to 100-150W for testing.
If there's a short or fault that develops, then it'll probably save a few parts. Especially some of the expensive igbts...
I did this on a TX-P42U30B repair although that worked first time... Was much simpler than these 13G panels tho
