I have the same problem as many others have had with their Samsung Syncmaster 205bw. It started being persnickety when I would first turn on the computer. The screen would be black for 6 seconds then flash on for half a second then go black again. The power light would also flash in sync with screen. The monitor, after about 10 min of flashing, would come on. A little inconvenient but doable. Started getting worse over a period of 2 months and now won't come on at all and just continues to flash.
I opened up the back and got the power supply out and looks like two Capxon 1000µf are a little puffy on the top. I want to replace all the caps on the board but am confused over, say Rubicon's MCZ, MBZ, etc. codes or Panasonic's FM, or FC codes. Which ones will be best for my monitor. If I wanted to buy these caps from Badcaps, can I list the caps info and have you or the forum make recommendations?
2 1000µf 25V 10x20mm C636 "The bad ones"
1 472uF 35V 10x16mm C634
1 470µfF 25V10x16mm C636
1 1uF 50V 5.25x11mm C632
1 10uF 50V 5.25x11mm C636
1 120uF 50V 18x42mm C636
Thanks for the caps website. It's a great resource!
