MB DELL GX270 replaced by MB GX280
    I try replace MB in my home PC.
    Oryginally i have DELL GX270 in tower case.
    I try install in this case GX280 small factor board .
    With hardware montage are'nt any problems , but i find some problems with power supply .
    GX280 boards with 3GHz CPU and 1 GB ram don't starts.
    This GX280 board work corect with my neighbours, 400W PSU .
    LED at the front panel very fast blink without pressing button ( about 10 Hz) in green colors.
    Oryginally i have DELL PS model HP-P2507FWP ( 250 W) , i check with another one the same PSU .
    This PSU work OK with GX270 , all bad cappacitors inside was replaced 2 years ago .
    Really GX280 need PSU with more power?
    Can i make some trick with my PSU for solving this problem?
    Re: MB DELL GX270 replaced by MB GX280
    The GX270 and GX280 front panel connector is different. Probably something in there shorted. Try bench testing the board. The PSU shouldn't be a factor (unless its bad), a good one would run either one.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      I not agree with you ,Topcat, GX270 and GX280 front panel connector is the same or similar, because with this panel , with 400W PSU, this GX280 board starts.
