Here are the list of caps on the board inside the subwoofer:
1) 25V 4700uF 16mm x 31.5mm Samxon "GS"
2) 16V 470uF 8mm x 12mm Samxon "GR"
3) 16V 470uF 8mm x 12mm Samxon "GR"
4) 16V 470uF 8mm x 12mm Samxon "GR"
5) 25V 100uF 6mm x 12.5mm Samxon "GR"
6) 25V 10uF 5mm x 11.5mm Samxon "GR"
7) 25V 10uF 5mm x 11.5mm Samxon "GR"
8) 10V 100uF 5mm x 7mm Samxon "SS"
9) 16V 10uF 4mm x 7mm Samxon "SS"
10) 50V 0.47uF 4mm x 7mm Samxon "SS"
My question is like this:
In PSUs, the rule is that the quality of the main filter caps is not as important as the secondary filter caps because of the low frequency. The way I understand it, in a computer PSU, the wall AC voltage goes through the bridge rectifier and then to the main caps, and then to the high frequency switching transistors.
But this sub uses a transformer first to step down the AC to what I imagine is 16V or so, goes through the foru-diode rectification, then goes unregulated through the main filter cap (And that's why it must be over 16V), and only then does it pass through the switching transistor. So this is effectively a wall wart adapter.
So, previously I have found many bad caps in AC to DC wall warts. Is there high frequency ripple going to these caps, and do you need a high quality part in these applications, unlike in computer PSUs?
Also, I am looking to purchase the main big 25V 4700uF filter cap, but I don't want to spend that much just for one single cap at Digikey... Does anyone have any cap of this type lying around that they would care to sell?
I can probably squeeze an 18mm cap in there, but the height is very important since the board won't slide back in unless the main cap clears it. I think 35mm is the absolute maximum.
