I got bad chip on my Quadro FX3700M, it's G92-985-A2. I was wondering how to find latest revision of this chip if someone can tell me, because I heard that a lot of those G92-985-A2 chips are faulty for some reason and I was planning to buy new one but this time latest revision so that I can avoid problems assuming they fixed it in that latest revision.
Laptop GPU Chip info.
Re: Laptop GPU Chip info.
specifying that all tests do not provide a definite answer,
If the chip is not soldered you can measure the VCC inputs respect to ground or if the pads are hard to find, measure whether the capacitors are shorted.
Do not take measurements with diode test but in ohms.
If the chip is welded, then a possible short can come from the power lines that must be disconnected.
However that is the case where the GPU chip is seriously damaged, and probably the motherboard not turn on, if there are internal connections that are disconnected randomly , the only way to test the chip is to use a test socket with a dedicated motherboard.
I need to order that chip can someone help me not to get some refurbished junk, any trusted good sellers on sight ?Last edited by Thermaltake; 12-23-2016, 03:09 PM.
In recent years, I tried to buy from different vendors.
There are chips that are easily damaged than others, especially if are handled many times, for example , I never buy an 216-0752001. I always prefer to take the chip from a motherboard that has other problems.
For the reason that I know where it comes from and I prefer to do a reballing with the "tin lead" balls and not lead free. This is Because it is easier to solder (without having to use a very professional soldering station) and free "pad ball pad" is stronger.
All chips that I purchase are converted to lead-tin.
One of the most popular vendors is e-best_trade (http://www.ebay.it/itm/1-Piece-New-N...94082881?hash= item3f364ef141: g: bWIAAOxyItRTdtJM) the price is not low.Last edited by jasko_jacker; 12-24-2016, 08:33 AM.
hmm same seller
33.80$
here
http://www.ebay.com/itm/1-Piece-NVID...IAAOxyItRTdtJM
what's the catch ?
Originally posted by jasko_jacker View PostIt's used
I Didn't read condition status my bad. I found on .com that same "new" one. Hope that it is really new.Last edited by Thermaltake; 12-25-2016, 05:05 AM.
Problem solved, new chip bought, I mean not new but used and working from other chinese from aliexpress that I remember buying before stuff and it was always working and every item was in good condition so I bought from him, and it was much less than from seller suggested on ebay up in the post. Quadro graphic card is working now fully test for few days now.Last edited by Thermaltake; 01-20-2017, 04:55 PM.
of course
here:
Code:https://www.aliexpress.com/store/2025103
