Visitor Messages
  • Dblueman
    • Nov 2012
    • 84
    Tom,
    I apologize if I seem like I'm bothering you. Not sure what (PMD) is. You're the only one who responded to my post. On the NEC Plasma 42MP3 aka Px42VM3A that I posted about having no display.
    And I do get the Sparkleys, like you mentioned.
    You mentioned that usaually it's an audio board that has a tendancee to go bad which sends a weird signal to the display and that is probily my issue. Inside of the unit there are 2 boards. 1 is the speaker input and the other is what I would call the main feed, as you can see from my pictures it's a smaller brown tan board with a few Caps on it. The # on the board is 50-32188-01 PD-MA-2 3S130221. Would this be the board I should change or should I change the speaker input board. I tried replacing the T-CON board because someone else mentioned I should due that instead, but that didn't fix my issue. I know you're a busy person so when you get a chance give me shout back. Thanks for your help.
widgetinstance 457 (Related Topics) skipped due to lack of content & hide_module_if_empty option.
