Testing and ESD Strap?
  • Nerfinator
    • Feb 2015
    • 56
    I bought 3 ESD straps, they were cheap and so I thought, well I'm going to test it. I put my multimeter to continuity, put one probe on the clamp of the ESD and touched the plate on the band side, no sound and no change on the meter. I know my meter is good and all 3 bands do this under the test.
    Am I correct in that all 3 of these straps are bad or am I missing something?
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    • Electronics, music, computers.
    Re: Testing and ESD Strap?
    ESD straps have a megohm or more resistance by design.
    • Nerfinator
      • Feb 2015
      • 56
      I did not know that. How can I test to make sure it works?
      • Radio Fox
        • Jan 2010
        • 281
        Set your multimeter to a higher resistance range.
        ________________________________________________
        Invisible airwaves crackle with life
        Bright antennae bristle with the energy
        • Nerfinator
          • Feb 2015
          • 56
          Thank you, I'm pretty new to electronics and really appreciate the reply. All 3 ESDs measure at about 990 resistance.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8824
            • Fixing Failed Fuhjyyus
            As a scientist, the warning to you: make sure you get your units right. 990 ohms sounds too low, 990 K ohms is probably what you read.
            • vladimir1909
              LlamaTester Alpha V0.1 Macbook Quick test
              by vladimir1909
              I would like to share a small MacBook diagnostic application that I've been developing. The goal of this tool is to provide technicians and repair enthusiasts with a simple way to test and gather information about a MacBook. Current features
              • Display test
              • Keyboard test
              • Camera test
              • Audio test
              • System overview with relevant hardware information
              • Charger and power adapter information
              The application currently works on macOS Monterey and newer versions.
              Please note that this is still an alpha release, so you may encounter bugs or incomplete...
              07-09-2026, 12:07 PM
            • chth96
              by chth96
              03-09-2024, 10:03 PM
            • lmcancu
              LED Strip test points and testing?
              by lmcancu
              Hi is there a guide in this forum on how to test the LED backlight TV strips? I purchased an LED tester on amazon, but I am a bit confused on the test points and how to test the individual LEDs? I took apart a RCA 43" TV Rlded4331b. Please see attached pictures. I understand that all the LEDs are in series, but on these strips I don't see any individual test points for each LED? Any tips or guides?
              Thanks in advance...
              03-20-2023, 07:52 AM
            • flat-earther
              LED VS incandescent light bulbs
              by flat-earther
              There was a period when I changed to LED lights, they use much less power than incandescents, which was appealing.
              But then I learned about some downsides of LEDs, such as blue light, and another one that I've seen called by several names, high frequency voltage transients, dirty electricity. EMI, microsurge electrical pollution, harmonics, dirty power, high frequency noise on wiring.
              The wiring in houses should only have 50 or 60Hz, but allegedly the high frequencies induced onto house wiring from LEDs and other devices that create the electrical pollution are in the thousands...
              06-25-2026, 11:17 PM
            • VladStar
              Repairing CyberPower CST1300ALU UPS
              by VladStar
              After repairing my first CyberPower 1350 UPS, I've decided to try to repair another one, namely CyberPower CST1300ALU (with two USB-A front ports).
              1) All fuses and diodes passed the test
              2) All capacitors tested ok (with the multi-meter in capacitor testing mode, without pulling them off the board). They either showed the value close to nominal or higher (which means some circuitry was involved).
              3) All transistors tested ok (with a multi-meter in diode testing mode), except two SM6002N - those had short circuits in one of the legs. Since they are connected in pairs,...
              03-21-2026, 12:59 PM
