Radial Electrolytic Capacitor Date Code Reading Instructions
  • yanz
    • Nov 2004
    • 910
    Panasonic's :
    http://www.panasonic.com/industrial/.../ecnotices.htm
    Please share any information/link you have about others cap manufacturers (Rubycon, Chemicon, Sanyo, Samxon, Elna, etc..).
  • Dale Cepull
    • Sep 2006
    Re: Radial Electrolytic Capacitor Date Code Reading Instructions
    These links are helpful, but they do not apply to the type of aluminum electrolytic I have. It is a PANASONIC(Matsushita) ECOS1CP103BA. This is their TS-UP series. The only numbers on the part that look like a datecode are:
    7342(M)
    Does anyone know how to decode this?
    • yanz
      • Nov 2004
      • 910
      Hmmm, I'm curious about that too. I look at my panasonic TS-HA 470uF 250V
      [M] CE(M)
      HA 105C
      470uF
      250V
      JAPAN
      7710
      The "7710" is in white writing. One will suspect it was made in 1997. To be honest im not sure how to decode that 4 numbers.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        • PC's, The Experts Exchange (same name there), Gardening, Hot Rods.
        77 = 1997 or 2007 , July
        If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
        Subscribe to support us. It only takes 1 minute:
        https://www.badcaps.net/settings/subscriptions
        • yanz
          • Nov 2004
          • 910
          1997 then, i believe.
          • capguru
            • May 2017
            typical capacitor date codes are in the YYWW (4 digit) format
            YY represents the last 2 digits of the year
            WW represents the week of that year
            so 8714 means
            1987
            14th week
            hope this helps
            • Fuzzy Fix
              0.00 ESR reading on a capacitor
              by Fuzzy Fix
              Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
              I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
              Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
              07-26-2024, 12:05 AM
            • cloudff7
              Electrolytic capacitor leak in storage?
              by cloudff7
              there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
              07-22-2024, 06:27 AM
            • jkucukov
              ASUS Zenbook 13 Laptop UX333FN Need Help with SMD Capacitor Identification
              by jkucukov
              I have a ASUS Zenbook 13 UX333FN motherboard that I need to replace a SMD capacitor. This SMD capacitor is located on the back side of the motherboard and is really small (C0201), however I need to find the specs of the capacitor (Voltage rating and Capacitance).
              I was fortunate to find Boardview file for however all I was able to get from the file is the Capacitor reference designator (C6353), here is the information:
              How would I be able to get Voltage rating and Capacitance of the SMD Capacitor?
              Thanks,...
              08-11-2026, 09:00 AM
            • Prolog
              by Prolog
              12-01-2024, 08:27 PM
            • badnocap
              Trouble reading this blown capacitor
              by badnocap
              25V 470uF? Any help would be appreciated! This was in an Adam A7X speaker. I replaced with a different uF and voltage closest to the values I thought because it is all I had in stock. It restored the speaker to working condition but it is certainly not what I needed to do as it is putting out less volume than its sister speaker which presumably no issues....
              11-12-2025, 01:36 PM
