philips 43pus6501 MB swap eq. no wifi
  • Ros2468
    • Feb 2022
    • 16
    • Norway
    I have this smart-tv that had a MB swap.
    Now The tv is ok but the wifi does not turn on.
    Is these wifi modules bound to their mb?
    Could i bga swap memory module from original mb? (maybe?)
  • William1967
    • Nov 2017
    • 217
    • Netherlands
    Re: philips 43pus6501 MB swap eq. no wifi
    No, Wifi is not bound to a mainboard. There is a 5V and a 3,3V Wifi used in these models, also there was a modification for the Wifi, an extra cable between the mainboard and Wifi module.
    • Guaculo
      Lenovo Yoga 11e BIOS chip swap for wifi card compatibility
      by Guaculo
      Hi, i got a Lenovo Yoga 11e that had a bad motherboard. I purchased a replacement motherboard but its a model variation from the original.
      Now the new motherboard wont boot with the OEM wifi card. On the lenovo page it says the new motherboard needs a N-7260 wifi card, and the one i have its a AC-7260.
      I swapped the 2 bios chip from the old mobo (U40 and U38) to the new one in hopes i could get the wifi card to run, but it wont work, even the serial number stays the same as the new motherboard (the laptop runs fine only this 2 issues).
      Is this information...
      10-17-2023, 09:33 AM
    • howardc64
      M557-G0 no WiFi/Bt no WIFIVendor file?
      by howardc64
      Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
      • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
      • Service Menu shows many Bt/Wifi info missing
      • Vizio app shows no WIFIVendor file
      Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
      • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
      10-15-2024, 01:12 PM
    • ugamazing
      820-00850 & 820-01949, No WiFi *In Recovery*
      by ugamazing
      I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
      1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
      2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
      01-25-2023, 05:39 PM
    • AlexVG
      Replacing the WiFi module on a vacuum cleaner iROBOT i7
      by AlexVG
      I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
      I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
      (This board does not respond, only the LEDs light up in a circle.
      The liquid damage is catastrophic and restoration is impractical).
      (I bought this board to get the WiFi module and camera).
      The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
      If...
      10-22-2024, 07:20 AM
      Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11P Hybrid (2-in-1) Studio Specification for Upgrade or Repair
      This specification for the Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11P boardview and Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11P schematic. Our users have donated over...
      09-07-2024, 04:10 AM
