65UJ6200 unable to get backlights on
  • lfhlaw
    • Mar 2014
    • 102
    I was able to get my hands on a LG 65UJ6200 with no backlights.
    Flashlight to the screen will show an image so I'm assuming the Panel is still okay.
    I can also hear sound as well.
    I replaced the LED strips with new ones.
    Tested them with the light tester.
    The LED Voltage at the pins will jump to about 340 or so at pin 11 and 12 when the TV is turned on but then drops. There is also a slight flicker with power on which is typical for bad LEDs. Interestingly, when I try to test the LED pins it appears due to the wiring, that I cannot just drive the LEDs with a test based on adjacent pins( I.e. 11-12, 8-9)
    I've looked at the Capacitors on the Powerboard and no bulging. Nothing stands out to me at the moment. Part of me feels it is still the PowerBoard, but unsure.
    I'm kinda stuck as where to look next.
  • R_J
    • 9535
    Re: 65UJ6200 unable to get backlights on
    You have a problem with the backlights, likely a bad connection on the distribution strip or at the plugs in the panel. to drive the strings you need to connect between LED1+ and LED1-
    I think your meter is being fooled by the unfiltered dc voltage to the led strings, also without any load the voltage will be high.
    • lfhlaw
      • Mar 2014
      • 102
      well found a replacement distribution strip on Ebay and will see if that works. I did, at one point, get a replacement power board but it did nothing for the LEds.
      • R_J
        • 9535
        It may just be a bad solder connection on one of the plugs, You can work on the backlights without having the LCD panel installed, after replacing backlights you should always make sure the backlights are working before reinstalling the lcd panel, this way there is less risk of damaging the panel.
        • lfhlaw
          • Mar 2014
          • 102
          Well I did replace the harness to LEDS and that didn't work.
          I Did however, get a T-con Board that got my lights back on.
          I put the TV back together and still had picture but after about an hr, the lights went again and now i'm back to picture being produced but no light.
          I'm guessing the Power board is bad and shorting the T-con? So I ordered another T-con and Powerboard from Tvpartstoday and that didn't seem to fix the issue.
          Crazy that I had picture for maybe an hr and then it went kaplooey again.
          • Diah
            • Feb 2013
            • 6357
            you have different at T_con firmware and main firmware..
            send in_stop to reset the tv to factory mode... search over here in_stop
            if this didn't help try to update.. if no update then downgrade with pc Apache server for lg.
            • lfhlaw
              • Mar 2014
              • 102
              not sure what the "in_stop" is? is that a typo or was it supposed to be a graphic?
              • Diah
                • Feb 2013
                • 6357
                i wrote search over this forum in_stop command for lg.... no typo,,, it IR code command send by service RC.. but if one don't have one there are alternative method to send the command from diy or mobile phone with IR sender
                • Pipolups
                  Corsair K70 LUX RGB dying LEDs
                  by Pipolups
                  Hi there !
                  I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                  Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                  10-08-2024, 11:58 AM
                • notallbad
                  TCL 55RP620K power board issue
                  by notallbad
                  Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                  0% p_dim at 1.65v and a_dim at 1v
                  50% p_dim at 3.3v and a_dim at 1.65v
                  100% p_dim at 3.3v and a_dim at 2.88v
                  Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                  Leds are 2 rows of 15 6v leds.
                  On inspection of the power board found diode MBR3200 shorted so replaced with...
                  07-12-2025, 05:45 AM
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • TrisHCl
                  LED TV Boot loop - UE40F6500SB
                  by TrisHCl
                  First post...
                  I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
                  Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
                  I disconnected the main board from the power...
                  02-06-2025, 08:42 AM
                • x_orange90_x
                  by x_orange90_x
                  01-29-2025, 09:24 PM
