sony kdl42w05a flickers the display after few minutes and after it comes dark
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hello everyone, I have the above TV sony kdl 42w05a and the problem is that it works for a few minutes and then it does this flickering on the screen and the screen goes black
    The problem is that when the screen goes black, the red LED does not flash to point me in the wrong direction, so I am asking someone experienced from you to tell me if they understand from the video where the error comes from
    I have measured the voltage of the main capacitor 397 volts, the capacitor for the backlight 137 volts and the second one exactly 83 volts
    I have 12.5 volts normally
    as soon as the problem happens and the screen goes black, while as you can see from the video, the white operation LED continues to light up, the voltage of the rear light is cut off, the voltage of 83 volts becomes 90 or 12.5 volts remains
    also when the problem arises it does not accept any command from the computer
    i suspect T con card
    can someone help me about this?
    or to guide me for subsequent active measurements?
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    Re: sony kdl42w05a flickers the display after few minutes and after it comes dark
    sorry kdl42w805a is the right model
    • beetle1303
      Sony KD-65X7000E - Screen double images for first few minutes then back to normal
      by beetle1303
      I have gotten this Sony KD-65X7000E TV completely dead. According to owner TV was working fine and suddenly blackout and not able to power on again.
      Checked and found D751 rectifying diode shorted, replaced and now power up and working almost normally:
      1) On power up - display double images, and flicker once every few seconds.
      2) After 3-4 minutes at this state - display suddenly back to perfectly normal (although there are few horizontal lines at the bottom of screen).
      3) Leaving on for few minutes, power off and on again will repeat the same...
      03-11-2023, 02:07 AM
    • u666sa
      HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
      by u666sa
      Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
      Platform: ipa32 la-m024p rev 1b
      Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
      I found a short on the other side:
      10-04-2025, 05:03 PM
    • Carlos#2003%
      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
      by Carlos#2003%
      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
      02-15-2024, 07:52 PM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-06-2024, 05:27 AM
