Samsung UN70TU7000BXZA
  • itronic
    • Sep 2015
    • 82
    • usa
    Anyone have a service manual for this unit. Having buffer board issue were screen flashes. Have a short above DA1 ESDProtectors . Remove DA1. Short still there. Check at Tp6 and tp13.
    See image below.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Samsung UN70TU7000BXZA
    Checked with or without the cable to the mainboard connected ? I don't think this TV has a tcon does it ?
      • 12144
      • U.S.
      not sure I follow, you said you removed DA1, and still have short on tp 13, isn't that tp on DA3, maybe DA3 is the problem?
      • itronic
        • Sep 2015
        • 82
        • usa
        This unit dont have a t-con board. This unit has 3 buffers boards. 1 main buffer and 2 small buffers. see pic below. I unhooked the small buffer on the left side looking from the back, and tv works fine.
        • itronic
          • Sep 2015
          • 82
          • usa
          not sure I follow, you said you removed DA1, and still have short on tp 6/13, isn't that tp on DA3, maybe DA3 is the problem?
          Tracing out points . It goes to DA1.
            • 12144
            • U.S.
            isnt tp 13 a pin on DA3?
              • 12144
              • U.S.
              Edit, ok, bad ribbon cable, that makes sense.
              • itronic
                • Sep 2015
                • 82
                • usa
                With more testing, found the issue. The ribbon cable going from the lcd panel to the buffer board is shorted. The small buffer board on the left side, first ribbon cable is problem. I tried to take the best pic as possible.
                • itronic
                  • Sep 2015
                  • 82
                  • usa
                  After removing the ESDProtector, I Tested and it read good. So put meter on the TP6 and TP13. It would short out every time I pushed in on ribbon cable. So after looking, it was hit with water damaged. Cleaned it and took pic. Time to recycle now lol.
                  • itronic
                    • Sep 2015
                    • 82
                    • usa
                    Thanks Nomoresonys and Diif for the response.
                      • 12144
                      • U.S.
                      So it works fine with that buffer board unhooked? wonder if it could be used by just leaving it uhnooked or maybe a jumper wire workaround.
                      • itronic
                        • Sep 2015
                        • 82
                        • usa
                        It worked fine, just 3/4 if screen showing. Are they any way to bypass it to show whole screen. Reckon the tape method would work?
                          • 12144
                          • U.S.
                          good idea, tape method is worth a shot.
                          • itronic
                            • Sep 2015
                            • 82
                            • usa
                            Any idea on which pins to bypass. We’re they no t-con board. I’m
                            Clueless
                              • 12144
                              • U.S.
                              guess it depends on where the problem is, seen a lot work with 5 or 6 pins blocked on one end, maybe starting with 2nd pin from the end, good video there, he figured out exactly which pin to block, maybe in some cases it needs to be more than one, theres a lot more videos about it on youtube: https://www.youtube.com/watch?v=pfrRhw7-ZII
                              • itronic
                                • Sep 2015
                                • 82
                                • usa
                                Okay thanks. Only problem is this tv don’t have a t-con board. Don’t really show the clk connection to bypass them. I’ll send picture of the main board cable connection. Also connection at main buffer board. Last 2 pic is the main board connection. Tape the pins and the marks but didn’t work.
                                  • 12144
                                  • U.S.
                                  did you try the tape on each end of the cable, meaning left and right? maybe cover 2-9 and make tape smaller by one line at a time.
                                  • cheebster
                                    • May 2008
                                    • 373
                                    If you see the short on the flex bonded tab, why dont you remove it there directly where you see it?
                                    • itronic
                                      • Sep 2015
                                      • 82
                                      • usa
                                      it burnt the flex bond cable and shorted out the pins in the flex bond cable going directly into the lcd itself. can them be fixed.
                                      • itronic
                                        • Sep 2015
                                        • 82
                                        • usa
                                        I found the exact pin that coming of mainboard to flex cable. Its pin number 81. Tape and the tv stays on but no image but has backlight, but does have sound. If i unhook left buffer board (looking from back) and have pin 81 tape, still no image but has backlight and sound. So they something checking each pin to let image come up im guessing.
                                          09-07-2024, 05:50 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
