Philips 65PUS6521/12 voltage fluctuation
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4456
    • Italy - Milan
    Re: Philips 65PUS6521/12 voltage fluctuation
    unrolling and rolling back a transformer is quite a simple thing,you need a caliper to ensure same size of wire, my first attempt was been good. No, hdmi miss it's a software problem or hdmi interface ic problem, that is usually the Silicon Image chip, probably a spike surge entered by the hrmi port and contemporarily by the psu input or ran backards from main board..
    • Gabriel
      • Jan 2010
      • 620
      • Norway
      I will try the SAM option first, I'll report back when it's done.
      • Bad_IC
        Philips TV 37pfl5604h/12 no standby voltage
        by Bad_IC
        I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
        These are the voltages in some pins of IC fsq510:
        Vcc=18v
        D=320v
        Vstr=154v
        Unfortunately, I couldn't find the schematic
        What else could I check?
        Is it possible to provide standby voltage from an external source to allow the TV to turn on?
        Thank you​...
        11-08-2024, 01:07 PM
      • Fernon@Repair
        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
        by Fernon@Repair
        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
        VCCIO voltage ok
        VCCSA Voltage OK
        VCCPLL Voltage OK
        Ram Voltage ok
        RamVTT OK
        VPP 2.5 OK
        But No Core Voltage
        and i want to this vrm ic datasheet or pinout (ISL69269)
        anyone have this ic pinout voltages?...
        06-25-2025, 07:19 AM
      • electron_jj
        Panasonic TH-L42D25A checking the PSU output voltage
        by electron_jj
        Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
        I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
        08-29-2021, 08:13 AM
        Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
        I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
        The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
        Now...
        06-09-2024, 10:57 AM
        ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
        3+1 Voltage Regulator for IMVP-7/VR12 CPUs
        Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
        core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
        configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
        serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
        Based on Intersil's Robust Ripple Regulator...
        11-05-2024, 03:24 PM
