Hisense 50r6- could a 65R6 main board be swapped in?
  • LemoneyF
    • Oct 2022
    • 5
    Hi all
    I have a 50r6 with a no power, no standby issue. (First post linked below).
    40mins on the phone to Hisense got me nowhere.
    After some digging I turned up this post from a bloke with the same power board. I was returning the same voltages. Following advice I passed 3.7v through the standby circuit and the outputs now read a stable 12v and 19.2v on VAMP. Would it be safe to rule out the power supply and focus on the main board? The main board handles the 3.7v feedback.
    I have found a 65R6 main board that is identical, though I would assume has been loaded with different firmware. What are my chances that this would work?
    There is also a 50R6 board at double the price.
    Power supply thread:
    https://www.badcaps.net/forum/showthread.php?p=1120104
    My first thread:
    https://www.badcaps.net/forum/showthread.php?t=111053
    Any thoughts appreciated thanks!
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
