OLED 55B6V only audio panel is black
  • Cento50
    • Oct 2022
    • 6
    • Italy
    OLED no display
    Lg oled 55b6v
    Hello friend to badcaps thank you for register to this forum.
    I have this problem.
    1- 24v go to 0v If have connected 4 flat cable panel and TV have only audio. And result D18 shorted.
    If disconnect 24v cable to tcon have this: TV on only audio. And result d18shorted.
    Vpres have short circuits, if disconnect 4 flat cable the diode D18 result good.
    Vpres is shorted and connected to tcon lock the 24v in protection. Have solution for investigate this little board?
    Thank s
  • Cento50
    • Oct 2022
    • 6
    • Italy
    Re: OLED 55B6V only audio panel is black
    Originally posted by Cento50
    OLED no display
    Lg oled 55b6v
    Thank s
    C8430 C8431 r side
    C9422 C9422 l side
    4 capacitor beep short with multimerter
    • Diah
      • Feb 2013
      • 6399
      you should cut the metal plate to have access to complete edge boards.. but if the short at cell row no way for repair..
      1- remove caps and check if the short remain or not.. if it remain.. keep yours DM on the shorted reading cap and with yours finger tap on the front panel glass carefully at corner and middle .. you may have the short peep ton stop... maybe..
      • Cento50
        • Oct 2022
        • 6
        • Italy
        I have chek this cap in the picture no have test peack to panel.
        Peack solve short?
        • Cento50
          • Oct 2022
          • 6
          • Italy
          This in the picture
          • Oled_gambler
            LG OLED; Component-level repair on OLED panel?
            by Oled_gambler
            So I gambled and (likely) lost $200 on a pair of OLED C1 televisions, hoping I can Frankenstein them into 1 working unit.
            one had a physically-damaged panel and the other had a panel that would display normally (with the exception of a single vertical white line down the left-hand side) but turn off after around 10 seconds. I believed I would find an overheated processor (common on the CX) or a failed power board (also common).
            Swapped the power, mainboard, and T-con from the dead panel TV and issue persists.
            Looks like the actual panel is at fault. I can...
            11-22-2024, 03:58 PM
          • samson7point1@yahoo.com
            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
            by samson7point1@yahoo.com
            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
            The player processes the audio signal using two different reference frequencies. The "R"...
            04-30-2024, 11:22 AM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-07-2024, 07:12 AM
            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
