F&U FL23406P standby blinks 7 times then nothing
  • filippia1981
    • Mar 2021
    • 29
    • Greece
    I have the aforementioned tv that presents the above issue. I checked with my backlight tester the backlight strips and they light on. I can see picture when I use the backlight tester. On the backlight connection at Power board I get 30V with backlight connected and 30V when the backlight is disconnected. The issue lays to the power board or backlight strips?
    kind regards
  • R_J
    • Jun 2012
    • 9588
    Re: F&U FL23406P standby blinks 7 times then nothing
    I suspect the backlight strips, likely one ore more shorted led's The power supply monitors the current and will shut down when there is a problem, the backlight tester will not and also supplies a much lower current when testing (only about 10~20ma)
    • filippia1981
      • Mar 2021
      • 29
      • Greece
      So do I have to open the tv and check the backlight strips?
      • Seb932
        LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
        by Seb932
        i'would like to fix my not working LG 49UB850V tv.
        Symptoms:
        -AC plugged in, Standby LED not working
        -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
        Checked already:
        -Powersupply Output in Standby => 3.5V ok
        -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
        Any suggestions what to check next?
        Thanks in advance!
        09-14-2023, 06:28 AM
      • brithepi2k
        Samsung UE75TU7020k No picture, Standby blinks 2 times
        by brithepi2k
        My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
        04-23-2025, 10:05 AM
      • Kingfreddie
        LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
        by Kingfreddie
        Ok.. this is the story:
        Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
        This is kinda how it looked, just that mine were at the bottom of the screen:
        09-11-2021, 01:57 AM
      • cekanayake
        L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
        by cekanayake
        I am a noob with some elementary knowledge trying to fix this TV that I have no history on. Any help or guidance will be much appreciated.
        When I first examined it was completely dead. saw that the fuse was blown and the ICM801CS blown. I searched and found that the FSFR1800HSL might be the replacement and got one from ebay and replaced it. But when I pulled the ICM801CS I could see the last 3 letters on the blown up part was XSL. So may be I replaced it with the incorrect part. I fixed the fuse and turned it on and it now gives me a standby light blinking twice five times, then clicks...
        04-19-2023, 08:37 AM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
