Samsung LE32C530F1W with vertical lines on Screen
  • Kambi13
    • Aug 2022
    • 134
    • Portugal
    Hello all, I'm dealing with a Samsung LE32C530F1W that now has vertical lines on the right side. It started with a ghost image on the top of the screen and then I tried the old trick of masking a few contacts in the flat cable that connects the T-Con board to the screen with some tape. It worked for a while and now out of the blue it turned into what you can see in the pic. I was able to get my hands on a known good T-Con board but the problem still persists. Now, what I've noticed is that the cooper colored flat cables that are directly connected to the screen itself are very hot to the touch (all four of them) in the right side. Left side is completly ok, they heat up a bit, but no problems there.
    Could this be motherboard related also.
    Anyone had a similar issue?
    Best Regards
    • 12306
    • U.S.
    Re: Samsung LE32C530F1W with vertical lines on Screen
    try pressing those tab bonds a little if you didn't already see if any change to display, can also check the cofs, look closely see if any look burnt or blacker than the rest.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4515
      • Italy - Milan
      lift the panel's board and flip it to see the part of attachement of the tab, then heat that slot with heat gun not much, the silver oxydization could turn back to full silver traces.
      • Stanley1843
        by Stanley1843
        06-29-2024, 11:54 AM
      • Falki
        Colorful LCD Vertical Lines on Samsung ue55es8090
        by Falki
        Hello there, ive recently found an older 55inch Samsung SmartTV.
        A similar issue has been posted as well but also with no actual response ...
        08-12-2025, 04:19 AM
      • ItalianSat
        LCD SAMSUNG LE40A656A1CXXE - Vertical Lines on Half of The Screen?
        by ItalianSat
        Hello Everybody,
        I have a 40 inch LCD SAMSUNG LE40A656A1CXXE. Its problem is that there are Vertical Lines on Right Half of The Screen.
        Interestingly enough, when I move my mouse (in the case if connected to a PC) or when I am watching the TV, lines also move. At first appearance, I had thought that the problem might arose from loose vertical ribbons (COF), but when I opened up the TV for further investigations, I realized that the problem cannot be solved by touching them.
        Moreover, I detached the T-CON board for a new round of investigation. I personally...
        06-28-2022, 06:02 AM
      • Firentiosi
        1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
        by Firentiosi
        Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
        The issues are as follows: the...
        11-27-2024, 12:33 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
