Oled cof tab bond Q&A
  • bman4
    • Jul 2015
    • 210
    • canada
    I have a 65b9 that is showing symptoms of a failed cof tab or
    bad bond.
    It flickers a double image on one side with horzontal black lines across.
    I'm trying to find someone that has a garbage panel with extreme burnin .
    i will need you to attempt to remove one side of cof tabs.
    This will require heating the panel and separating the screen like a cell phone or cutting the back open .
    I need to see if the oled functions like a lcd and will continue to work without causing a panel fault ect .
    I might be able to tape the tcon connection .
    It might be a bad memory chip on tcon or dirty connections.
    I read the tcon is married, even when they replace the panel it comes with the tcon, id rather remove the cof tabs.
    The black lines remind me of when i removed cof improperly and it left lines across the screen
    If this is the case we can get alot of these oled working again then possibly get new cofs installed.
    If you have a 65 b9, pm me !
  • William1967
    • Nov 2017
    • 210
    • Netherlands
    Re: Oled cof tab bond Q&A
    You think correctly about the COFs, but opening an OLED panel is very difficult and the chance of success is very small. The panel is glued all around. The chance that the panel will tear is very high, I succeeded with 1 model because there was a plastic edge around the panel that I could remove, if that edge is not there then you can forget it because the panel is so thin that it is almost immediately tears. You can forget to replace the COF, but you can remove a side COF.
    The pictures show how I got the panel opened a little, just enough to get the side COF's out on one side.
    The last picture shows how a Oled panel looks when the complete rear is removed, this panel was beyond repair and was cracked.
    • bman4
      • Jul 2015
      • 210
      • canada
      I see those also have the test points that people solder to, don't think that will fix my issue.
      Its all metal solid frame a couple mm thick , id have to practice trying to remove the glue on another .
      I feel like i can get a nail between the frame and the back seam .
      the glue might be solid non removable and the only chance might be to cut the back.
      After studying some videos on bad cof tabs they doo indeed produce a double image pulling down to the bottom like mine.
      Thank you,
      bman4
      • Diah
        • Feb 2013
        • 6376
        i would like to know which OLED Model William talking about? first generation or the one Samsung try to do it before..
        i scarped 4 OLED from LG different model there are no any side COF, the panel where OLED cells mounted on it covered from downside with reflection sheet. followed with Aluminum sheet to reduce Temperature and transfer it to metal base where the whole panel glued with it by double side type as 5-6 line depend on the size.
        so theory if you sink the whole panel in 98% alcohol ( not the edge down COF plate ) you can easy to operate the panel from the metal base.
        • bman4
          • Jul 2015
          • 210
          • canada
          I'm trying to acquire a lead on a similar looking model with the thin q style that has a cracked screen to study.
          Ive soaked my phone lcd with rubbing alcohol and it discoloured the screen.
          Seems to be heat on the side with the issue and cold on the opposite.
          I hope there is cof drivers.
          • William1967
            • Nov 2017
            • 210
            • Netherlands
            It was a 55EC930V silver colored plastic edge. There is a good chance that newer models do not have side COF's, you do not always see them with newer regular TVs.
            • TeslaMichael
              • Oct 2020
              • 102
              I tried opening the panel (55ec930v) long time ago and i was very careful but then panel cracked. I got also some images that I can post tomorrow. I would say it is almost impossible to open panel.
              • TeslaMichael
                • Oct 2020
                • 102
                • Oled_gambler
                  LG OLED; Component-level repair on OLED panel?
                  by Oled_gambler
                  So I gambled and (likely) lost $200 on a pair of OLED C1 televisions, hoping I can Frankenstein them into 1 working unit.
                  one had a physically-damaged panel and the other had a panel that would display normally (with the exception of a single vertical white line down the left-hand side) but turn off after around 10 seconds. I believed I would find an overheated processor (common on the CX) or a failed power board (also common).
                  Swapped the power, mainboard, and T-con from the dead panel TV and issue persists.
                  Looks like the actual panel is at fault. I can...
                  11-22-2024, 03:58 PM
                  Gigabyte AERO 16 OLED BSF-73DE994SO Notebook Specification for Upgrade or Repair
                  This specification for the Gigabyte AERO 16 OLED BSF-73DE994SO Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-73DE994SO boardview and 16 OLED BSF-73DE994SO schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-07-2024, 06:38 AM
                • howardc64
                  LG 49UJ6500 LCD panel lighter band that goes away
                  by howardc64
                  49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                  Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                  02-19-2023, 12:13 AM
                • triplefour
                  SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                  by triplefour
                  TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                  tcon is built into mainboard.
                  Only one cable goes to panel boards.
                  there is a cable from one panel board to the other that links them.
                  cost cutting measure that results in us having harder time to diagnose.
                  removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                  used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                  07-28-2022, 07:59 PM
                • Storyteller12
                  QN55Q60R Service Menu Panel Help
                  by Storyteller12
                  I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                  I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                  I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                  the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                  01-13-2024, 01:57 PM
