Hitachi 58HK6100U LED TV - Sound but No Picture
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Have a Hitachi 58HK6100U
    TV turns on, and sound is still heard, but no image, just blank white screen, with vertical lines.
    Im guessing either Tcon or Panel? Is there any known issues with these? Is there any tests I can perform to determine if its the Tcon? Or is it just a case of replace it and see?
    Any help grately appreciated.
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Re: Hitachi 58HK6100U LED TV - Sound but No Picture
    Have also tried unplugging left cable on Tcon, half the screen went blank, and other half still displayed the white picture with vertical lines, same as before.
    Unplugged the right cable, and half screen goes blank, but the other half displays the image correctly as a working TV would
    • dskall
      • Oct 2016
      • 2905
      • usa
      No doubt a panel problem. Short on panel?
      • Bloopeta
        • Jun 2018
        • 526
        • United Kingdom
        Would that be repairable?
        • dskall
          • Oct 2016
          • 2905
          • usa
          Maybe just a bad cap on bad side of panel board.
          • Bloopeta
            • Jun 2018
            • 526
            • United Kingdom
            Am I right in thinking, that if I check all the caps with DMM set to Ohms, and they all show readings consistent with others, and stabalise on a number they are fine?
            And if I get 1, where the reading just gets higher and higher, with no sign of stopping, that one is bad?
            C346 being the one in question
            • Bloopeta
              • Jun 2018
              • 526
              • United Kingdom
              And how do I know what capacitor I need to replace C346? I cant see anything written on it? I have never had to replace a capacitor like it before, i have only had experience with the larger cylindrical type, with the numbers are clearly written on the side.
              • diif
                • Feb 2014
                • 6978
                • England
                They usually fail short, occasionally open.
                • Bloopeta
                  • Jun 2018
                  • 526
                  • United Kingdom
                  Im pretty sure its the one Ive mentioned, but Ive no idea what the numbers are for it to purchase a replacement 🤣
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    First remove it and see if that fixes the problem.
                    • lotas
                      • Jan 2016
                      • 4618
                      • Russia
                      You can run without this capacitor, it does not play a big role.
                      • Bloopeta
                        • Jun 2018
                        • 526
                        • United Kingdom
                        Ah I wasnt aware of this, thankyou
                        • Bloopeta
                          • Jun 2018
                          • 526
                          • United Kingdom
                          I will try that thanks
                          • Bloopeta
                            • Jun 2018
                            • 526
                            • United Kingdom
                            So, I have removed it, and fault still exists.
                            Also If I use DMM on the board, with cap removed, but where it was positioned, I get the same outcome of reading just going up and up
                            • lotas
                              • Jan 2016
                              • 4618
                              • Russia
                              Disconnect the cable first, then measure the resistance on the ceramic capacitors in the faulty panel bar.
                              • Bloopeta
                                • Jun 2018
                                • 526
                                • United Kingdom
                                With the cable unplugged, Im mainly getting no readings on most???
                                What should I be looking for? If I set DMM to 20k Ohms
                                • lotas
                                  • Jan 2016
                                  • 4618
                                  • Russia
                                  You must find a capacitor that has a very low resistance (a few ohms), if the multimeter has a continuity, then the multimeter will beep on a faulty capacitor.
                                  • Bloopeta
                                    • Jun 2018
                                    • 526
                                    • United Kingdom
                                    None beep if I touch both ends of caps on continuity setting.
                                    However, with one MM probe to earth, and checking caps, they all beep except this one in pic C449. I also cannot get a reading set at 2k ohms
                                    • lotas
                                      • Jan 2016
                                      • 4618
                                      • Russia
                                      Basically, these are shunt capacitors for powering the matrix and one output will always be on ground.
                                      • Bloopeta
                                        • Jun 2018
                                        • 526
                                        • United Kingdom
                                        Ah I see, so that is fine then
                                        Any more suggestions as to what it would be and what I can try?
                                        • KYBOSH
                                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                          by KYBOSH
                                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                          No picture but you hear the TV static (white noise) playing loud and clear.
                                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                          But it seems they didn't get too far and just left it.
                                          When I first took a look I was amazed at how pristine the inside looked.
                                          Its as if the TV had been in a time capsule.
                                          Caps looked like they were just pulled off the self.
                                          Copper coils had no sign of corrosion on...
                                          02-01-2023, 11:10 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Fly_Among_Stars
                                          VIZIO E70-E3 Half picture with half TCON
                                          by Fly_Among_Stars
                                          I have a VIZIO E70-E3.
                                          Symptoms: Black screen, no picture, but LED backlights are working.
                                          I probed the power board and voltages are as listed on the board.
                                          Main board appears fine, too.
                                          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                          There are two separate ribbon cables feeding the LCD.
                                          If both are connected, the screen is black.
                                          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                          04-24-2023, 08:20 PM
