Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
  • polaro
    • Aug 2022
    Greetings,
    I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks
  • neilc6
    • Nov 2015
    • 1550
    Re: Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
    Failing panel. Google Sony tcon training manual. Your model has an integrated tcon and no separate tcon board.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4476
      • Italy - Milan
      bad source cof soldering
      • Falki
        Colorful LCD Vertical Lines on Samsung ue55es8090
        by Falki
        Hello there, ive recently found an older 55inch Samsung SmartTV.
        A similar issue has been posted as well but also with no actual response ...
        08-12-2025, 04:19 AM
      • Stanley1843
        by Stanley1843
        06-29-2024, 11:54 AM
      • x_orange90_x
        Samsung UN46C8000XFXZA vertical bars/horizontal lines
        by x_orange90_x
        I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
        The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
        09-04-2023, 12:09 PM
        09-07-2024, 05:50 AM
      • Anonmis
        Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
        by Anonmis
        Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
        The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
        12-01-2023, 04:31 PM
