Hisense 58R6009 T-Con board shorted chip
  • Yanleb
    • May 2017
    • 102
    Hi, I'm working on a Hisense 58R6009 with a bad T-Con board. InnoLux T-Con board model MACDJ4050 (BVLC0A6AH394104PB00001). The LCD screen was displaying only washed out vertical lines.
    The main chip, an INX IN8208A EN2, was heating a lot. The only replacement I found is an IN8208A N2.
    After replacement the chip doesn't heat as before, but now I'm stuck with a completely black screen.
    My question is: Is the IN8208A N2 compatible with the IN8208A EN2?
    Thanks.
  • alfatv
    • Sep 2020
    • 353
    Re: Hisense 58R6009 T-Con board shorted chip
    Those T-con chips typically have custom programming. So if numbers are different, no guarantee of compatibility.
    Better find replacement T-con, make sure part number is identical.
    • dskall
      • Oct 2016
      • 2905
      • usa
      I would double check for shorted pins and unsoldered pins.
      • Yanleb
        • May 2017
        • 102
        Soldering of the chip has been done under a microscope. I already checked for shorts and loose pins.
        When double checking the test points I can see a missing 3.3 volt. I'll address that.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4427
          • Italy - Milan
          Not good the troubleshooting of the board for me, first power supply circuits must be checked.. a faulty mosfet on the converter for the main chip vcore can provide 12v instead of 1-3v to it..
          • Yanleb
            • May 2017
            • 102
            Of course all the power circuitry has been checked.
            But I've been able to find a used T-Con board for 9$. The seller had two. Since the shipping was 30$ which is high compared to what he was asking for the board, I bought the two.
            Same problem with the 3 boards. Screen only displays washed out vertical lines. All the voltages on the two screen bottom boards have been checked.
            I've seen a few videos on youtube showing people masking some traces on the ribbon connector between the T-Con board and the screen, and it solves the problem in their case. Since the videos are in foreign languages, I cannot understand the fix or which traces are masked. Do you have an idea?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4427
              • Italy - Milan
              There's no way to open a thread for a video defect without making some picture of the screen.. my opinion..
              • Yanleb
                • May 2017
                • 102
                Yeah you are right. Don't forget that my initial question was about compatibility of the two chips. Here is a picture of my problem.
                And what about my question? Do you know why cutting lines between the T-Con board and the LCD panel makes them work again?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4427
                  • Italy - Milan
                  already seen this behaviour, seems to me is the main processor, but to be sure try to press main processor and see if lines go away, there is something also on YouTube. I don't think chips are compatible. And on repl. tcon the main chip is still heating too much? Does it prevents to keep a finger on it?
                  • Yanleb
                    • May 2017
                    • 102
                    Hi all. I returned working on this TV set after leaving it on the side for 5 weeks. When I powered it ON I saw smoke coming from one of the COF. And yeah, short on the 1.8 volt line. The panel is now trash.
                    I've ripped off the flex cable from its board to remove the short and it restored the 1.8 volt line. Still no picture. Using a 200MHz scope I see no activity at all going to the LVDS cable. I tried with the T-Con board disconnected from the panel, and with the T-Con board disconnected from the main board. Still no signal on the LVDS cable.
                    I've tried to find the datasheet for the LCD panel. It is a V580DJ4-Q01 Rev. C4 by Innolux. One website has the datasheets:
                    https://www.panelook.com/V580DJ4-Q01...ter_35850.html
                    But you have to be member to download it. Guys, where are you finding that kind of information? I'm most interested to know if there's any kind of feedback or error report from the T-Con board to the main board. I suspect that the main processor doesn't even try to send a signal.
                    I properly reballed the processor. Actually, a reball, not a reflow. Still the same problem. Even if the LCD panel is trash I want to actually make sure that the main board is good before reselling it.
                    Thanks in advance for your help.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Short of the panel, the only way I know to test it would be mainboard tester.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4427
                        • Italy - Milan
                        tabs on the faulty side must be removed all
                        • Yanleb
                          • May 2017
                          • 102
                          A Main Board Tester. This is an interesting device. I didn't know it exists.
                          I've already disconnected the flat cable going from the T-Con board to the shorted side of the panel. Still no picture.
                          As I said, the main board doesn't send a signal to the T-Con Board through the LVDS cable. Even with the LVDS cable disconnected between the main board and the T-Con board I don't see any kind of signal using my 200MHz oscilloscope.
                          I wanted to know if there's any kind of error reporting or feedback from the T-Con board to the main board. This would explain why the main board doesn't output any signal if it is seeing an error coming from the T-Con board.
                          I do have sound, but no picture at all. No LVDS signal.
                          There's a few (not many) Innolux documents. Here is one. It is not the right one for my LCD panel (as I said, I found the right one but I need an account to download). Do you see any any pin carrying a signal FROM the T-Con board TO the main board?
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4427
                            • Italy - Milan
                            There is always an i2c serial communication, if panel have problems, tcon stops power supplying and video signal, probably a fault signal comes back to mb
                            • Yanleb
                              • May 2017
                              • 102
                              From the spec sheet I linked can you lead me to that i2c communication? I've looked without success.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4427
                                • Italy - Milan
                                This datasheet is very strange, there are pinouts only for internal panel connections not that from main board to tcon.
                                • Hakuu
                                  by Hakuu
                                  Hi There,
                                  More Details
                                  TV Model - LG OLED77G1PUA
                                  07-12-2023, 02:37 PM
                                • advant
                                  by advant
                                  02-03-2020, 12:25 AM
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
                                • modtool
                                  HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                  by modtool
                                  Hi to all,
                                  the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                  I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                  I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                  04-01-2025, 08:22 AM
