Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
  • Diah
    • Feb 2013
    • 6500
    Re: Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
    take out the bezel and inspect the screen rand glass you will may find broken line of vcc3V
      • 12312
      • U.S.
      it can work even with no side working but sometimes it won't.
        • 12312
        • U.S.
        I've seen it explained many times but still not sure exactly how it works, I just consider it magic when it does work. some explanation there by a very wise man: https://www.youtube.com/watch?v=pfrRhw7-ZII
        • ermals
          • Aug 2022
          • 12
          I've seen it explained many times but still not sure exactly how it works, I just consider it magic when it does work. some explanation there: https://www.youtube.com/watch?v=pfrRhw7-ZII
          I took the ribbon cables out from T-Con to Panel Boards to inspect them, I'm assuming the issue is related to the highlighted box in the attached image. I wonder how this could have happened as this TV has never been taken apart before.
            • 12312
            • U.S.
            Eureka that's it, shit we should have checked that first, that's why I always try to do the basic simple inspections first, can save a shit-ton of chasing the wrong thing.
              • 12312
              • U.S.
              #26
              you might be able to trim it off evenly and make it work or just get another cable.
              • ermals
                • Aug 2022
                • 12
                Tried trimming, with no luck. Going to order some new ones and come back with an update! Thanks for all your help.
                  • 12312
                  • U.S.
                  #28
                  No problem, I'm glad it was something easy to fix and not a shorted panel.
                    • 12312
                    • U.S.
                    #29
                    inspect the connector it came out of, make sure there's nothing wrong that will mess up the new one.
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • ohren
                      by ohren
                      09-08-2023, 05:24 PM
                      09-07-2024, 05:50 AM
                    • Asraf Atb
                      by Asraf Atb
                      01-27-2025, 05:02 PM
