Samsung UE46EH5000 - Flashing red light but not turning on
    • 12241
    • U.S.
    Re: Samsung UE46EH5000 - Flashing red light but not turning on
    so what did the diodes read out of circuit?
      • 12241
      • U.S.
      did you get an esr reading on those caps, if it's gone too high they won't work right.
      • dskall
        • Oct 2016
        • 2905
        • usa
        I would check CM813
          • 12241
          • U.S.
          from the bottom of board trace that diode to the next component check that and continue, kind of hard to tell from here without good clear focused pictures of bottom of board.
            • 12241
            • U.S.
            ok I'm not exactly sure because of bad memory, but I think I saw somewhere that if you have the boosted voltage of around 400 on the big cap/s, that everything up to that point is ok, if that's true then it would have to be after the big cap where the problem is.
            • Phil289
              • Nov 2021
              • 42
              Have checked the hole that the diode fixes to and it runs up to what looks like a transformer which goes from the hot side to the cold side but more worrying is that it seems to be shorted to the chassis (ie if i use my ohms meter or continuity setting it bleeps or gives a dead short)
              I have attached 2 pictures of the bottom of the board to clarify.The hole in the center of the rear of the board is the ‘shorted' hole.
              Esr readings for the caps were
              25v 470uf = 0.06
              10v 1200uf = 0.03
              25v 470uf = 0.04
              200v 47uf = 0.24
              350v 22uf = 1.7
              The 3 diodes are SR510 OC02
              I'm not really sure how to measure them but on my diode tester they read 283 and on a 20k ohms scale they read 1.64 - how should i measure them?
              Do you think the transformer could have blown?
              Thanks for helping I probably would have given up ages ago without the guidance here but it also a good learning curve 🙂
              • Phil289
                • Nov 2021
                • 42
                Originally posted by dskall
                I would check CM813
                Should i remove it and test it ?
                It looks like a different type of cap
                Thanks for your input 🙂
                  • 12241
                  • U.S.
                  #28
                  probably schottky diode, so 283 in one direction and l in other direction out of circuit is probably ok.
                    • 12241
                    • U.S.
                    #29
                    DM856 looks like it needs a solder touch up or is it one you took out and put back?
                    • Phil289
                      • Nov 2021
                      • 42
                      Yes its just one i removed and then refitted quickly just so I could see if the diode returned to being in a faulty state again - i had intended to replace all 3 with new ones but i think there's something else faulty and its not the diodes at all.
                      It maybe a case of waiting until i can find a replacement board on ebay as I'm convinced its the power board that's causing the problems but is becoming quite difficult to pinpoint what part or parts have become faulty.
                      Best price i can see at the moment is £45 but that's quite alot to spend on a 10 year old tv.
                      My board is a rev1.2 and its a shame because they have a rev1.3 for £20 and it looks like it has all the right connections but I'm not sure if it would work even though its listed for the same model number.
                      • Phil289
                        • Nov 2021
                        • 42
                        So just a question in theory
                        If a power board is listed to fit a certain make/model tv and is just a newer revision would it be compatible to replace an older revision/version?
                        I can see my rev 2 is 2010 and the rev 3 is 2012 but everything thing else looks the same.
                        Would it just supersede the old one?
                        Any idea?
                          • 12241
                          • U.S.
                          #32
                          it should work if the connectors are the same and it's for the same model and size tv, like you have a 46 inch so if its 46 and matches the other, it should work, powerboards are not as specific as mainboards.
                          • Phil289
                            • Nov 2021
                            • 42
                            Got one ordered so we will see what happens when it arrives 🙂
                            • Phil289
                              • Nov 2021
                              • 42
                              A quick update
                              Replacement Rev1.3 board arrived and tv back working fine.
                              Would have been nice to have pinpointed what was exactly wrong with the old one but it was starting to be out of my abilities but i'm really pleased it didn't end up in the bin 😀
                              A big thank you to nomoresonys and dskall for all your suggestions & guidance - i have learned alot from this and will put it to good use when the next one comes along 🙂
                              Just need to find out why the remote is not working and screw the back on- then on to the next !
                              Thanks very much 👍
                                • 12241
                                • U.S.
                                #35
                                Glad to hear it, thanks for the followup,
                                  • 12241
                                  • U.S.
                                  #36
                                  wonder if it needs pairing: https://www.samsung.com/my/support/t...s-not-working/
                                  • Phil289
                                    • Nov 2021
                                    • 42
                                    I'm not sure it's even the right remote for the tv - its a Rc1900/30063114 universal that came with it but according to google they are for vestel sets.
                                    Have contacted the lady i got it from to see if she gave me the right one but I don't think she did. 🙂
                                      • 12241
                                      • U.S.
                                      #38
                                      I don't think its compatible, do you have another universal remote you can try? :https://all-remotes.online/en/18409-...e-control.html
                                      • Phil289
                                        • Nov 2021
                                        • 42
                                        Spoke to her and she gave me the wrong one - so am collecting the right one on thursday - Happy days
                                          09-07-2024, 05:50 AM
                                        • Bloopeta
                                          Samsung UE43KU6400U Flashing Red Standby Light
                                          by Bloopeta
                                          Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                                          Power button does nothing
                                          Have unplugged the mainboard, and backlights illuminate.
                                          Have tried removing panel ribbon cables one at a time, and that makes no change.
                                          With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                                          Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                                          09-11-2023, 02:34 AM
                                        • 7ony
                                          Samsung plasma - flashing standby light
                                          by 7ony
                                          The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                                          Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                                          Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                                          No visible...
                                          08-31-2020, 05:18 PM
                                        • mrhaman
                                          SAMSUNG UE48JU6470U Red light flash loop
                                          by mrhaman
                                          06-20-2024, 03:59 AM
                                        • Deeloc
                                          How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
                                          by Deeloc
                                          I have a 1tb WALRAM SSD (Photo)
                                          Controller SM2259XT2G (photo)
                                          Samsung memory (photo):
                                          Part Number K9DVGB8J1B DCK0
                                          Name V-NAND V6
                                          Type TLC
                                          The SSD itself is detected as 1gb, but is not initialized.
                                          There is a Sata to USB adapter
                                          A lot of SMI MPTool, did not flash it. compare flash fail (17)
                                          K9DVGB8J1B is not listed anywhere
                                          What to flash?​...
                                          06-05-2024, 08:32 AM
