Vizio 40” V405-H19 has backlight, no display
    • 12156
    • U.S.
    Re: Vizio 40” V405-H19 has backlight, no display
    might have gotten a bad mainboard from sj, maybe send it back and have them send you another.
    • triplefour
      • May 2014
      • 1747
      Good lord. Here I was complaining about tcons being built into main boards but this guy's got a tcon built into the panel board! Vizio is one step ahead in the cost cutting / making it hard to fix game
      Don't fear the repair...
      • triplefour
        • May 2014
        • 1747
        But if the vgh and vhl are wrong, isn't that something only related to the tcon? Genuinely asking cause I don't know where those voltages are generated.
        • dskall
          • Oct 2016
          • 2905
          • usa
          VGH and VGL are generated on t-con.
          • triplefour
            • May 2014
            • 1747
            Thanks. Thats what I suspected. So in this case it couldn't be a main board problem making those vgh and vgl wrong?
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              As far as voltages the main only supplies 12v. Required panel voltages are generated by t-con
              • triplefour
                • May 2014
                • 1747
                The main board has to give the tcon some other small voltage signals for the picture data...most of the pins on the connector going to the tcon are those, right? And a few are for the 12v. I guess I should try lookup a pinout to see for sure what the mb sends.
                Also while they're busy integrating boards that they shouldnt be, who's to say they haven't put half of the "tcon" on the mainboard and the other half on the panel boards??
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #28
                  The main supplies 12v, data signals and some other information. The t-con generates the required panel voltages and timing signals to run the panel. The chip around your vgh and vgl test point is probably the one generating those voltages. So you either have a short or bad ic.
                    • 12156
                    • U.S.
                    #29
                    ok, if tcon is on the panel not mainboard, might be the dc to dc converter ic.
                    • mattd1979
                      • Apr 2014
                      • 30
                      Wow, that was a lot of information and good Q/A. Is there a way to test the IC? I suppose I would need a pin out diagram and what the voltages should be.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        #31
                        You could check those test points for shorts. You could cut the traces and check the voltage. Check the caps around the ic. Check for 12v to the ic.
                          • 12156
                          • U.S.
                          #32
                          I don't know exactly how they work either but I think you want to look for 12v going in and 3.3v coming out on one of the pins.
                          • mattd1979
                            • Apr 2014
                            • 30
                            Which of the 3 ICs do I check?
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              #34
                              Looks like right one.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                #35
                                There will be different voltages on each on the coils, so it's the middle and right but identify the markings to be sure.
                                • mattd1979
                                  • Apr 2014
                                  • 30
                                  The only two voltages I found close to what you were asking was pin 1 starting from the top left above the “I” in “INX” which measured at 4.970V and pin 3 above the “N” at 12.63V. I tried looking up the chip but couldn't find anything specific.
                                  • mattd1979
                                    • Apr 2014
                                    • 30
                                    I included the above drawing. Hopefully you can make sense of my scribble.
                                    I still need to draw a diagram of the other chip but I measured 12.63 volts as well as 5v. There were other voltages that measured between .600 and 1.5 volts.
                                      • 12156
                                      • U.S.
                                      #38
                                      I can't seem to find a datasheet on it either.
                                      • triplefour
                                        • May 2014
                                        • 1747
                                        Nice...tcon integrated into panel boards and secret ICs... they really don't want you to fix these
                                        If that ic is bad and there's no way to buy a new one then your only chance would be to take it from another TV but most ebay sellers don't tear off and sell the panel boards. Now that the tcon chips are there, maybe they should. I've been saving all my panel boards even tho they don't have tcon on them.
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
