TCL 55P607 / 55P605 tcon dump
  • ziddey
    • Sep 2015
    • 35
    • usa
    Picked up this tv in non-working condition. On plug, the backlight would come on, and the led would flash about 16 times before cycling. So my initial guess was a fault with the mainboard. However, after holding down the reset button and plugging in power, it actually booted and stayed on. Still no display, but backlights good, and could hear roku sounds when pressing physical/remote buttons. No more cycling.
    Next, detached one panel ribbon at a time, and got the respective white half, and banding on the other. Tcon seemed like common / likely culprit and are available cheap. Confirmed it revived the tv.
    Saw replacement flash chips being sold as well, so I did some testing. Dumped the bad flash repeatedly and got consistent results. Dumped the good flash, flashed it on the bad one, and verified a bunch of times. Chip seems to be fine?
    Retested the bad tcon and it's back to working. Closed the tv back up with the now working original tcon board, and will save the replacement for a rainy day.
    So I'm curious what happened here? It seems like something was corrupt both on the mainboard (that was fixed with a reset) and tcon. Perhaps I'll be looking at a replacement mainboard in the near future?
    Anyway, the problem tcon board is ST5461D04-1-C-7. Looks like it's used on a few different models as well. Flash chip is at IC6: GigaDevice 25Q41BT 4Mbit SOP8. AsProgrammer detected it as GD25Q40
    Attaching the dump from the working tcon. Hope it helps someone in the future.
    md5sum: d840252fccd1ea1a70bf36148d34c68d
  • CapLeaker
    Leaking Member
    • 8036
    Re: TCL 55P607 / 55P605 tcon dump
    Maybe buggy firmware, or a gone bad firmware update?
    • handsworth
      • Oct 2015
      • 174
      Thanks. I picked this one up today off the curb. Plugged it up and immediately thought Tcon. Had same symptoms as yours. ( blank screen ). Had good tcon leftover from 55S405. Tv works.
      • gpatadia
        • Sep 2015
        • 15
        • India
        hi ziddey
        can you upload that dump
        • ziddey
          • Sep 2015
          • 35
          • usa
          not sure what happened to the attachment. here it is again
          • gpatadia
            • Sep 2015
            • 15
            • India
            thanks
            • howardc64
              • Jun 2017
              • 543
              Keep getting "Invalid File Specified" when trying to download the ST5461D04-1-C-7 T-Con flash rom file. Anyone else having access difficulty? Pics on post #1 don't post either.
              • Diah
                • Feb 2013
                • 6353
                how about this
                • lotas
                  • Jan 2016
                  • 4499
                  • Russia
                  I downloaded from the first post and from the fifth one too, everything is fine, but some photos are now opening with errors....
                  • howardc64
                    • Jun 2017
                    • 543
                    Thanks Diah Yours and post #1/#5 downloads fine now as well as pics showing properly in #1. I guess server glitch.
                    My rom file differs (a bunch of random bytes) from these. TV (TCL 55S405) at a travel location so will install the flashed tcon in 2-3 months and report back.
                    • howardc64
                      • Jun 2017
                      • 543
                      Acquired another TCL 55S405 with backlight but no screen. Failure is exactly same with TCON flash corruption. Looks like TCON ST5461D04-1-C-7 is prone to this failure. Here are some stats + failed ROM dumps and comparisons.
                      - 2x TCL 55S405 with TCON board ST5461D04-1-C-7 with backlight on and display blank
                      - Both TCON flashed with good.bin from post #1 and TV works.
                      - Diffing good.bin with both failed flash TCON image shows mostly single bit errors often in the same bit within the byte.
                      - Diffing both failed TCON flash image shows they are EXACTLY the same except a single bit.
                      So why is this failure so common? (ebay seller seems to sell many of these flash chip preflashed with good image, presumably same as good.bin)
                      - system update caused corruption?
                      - flash chip random corruption? These are NOR flash technology which is for high durabiity and reliability
                      Will use these TVs with good.bin flashed TCON and see if stays working. Also will electrical tape the buffer board guard as preventive for future flex+COF failures.
                      Both failed TCON flash image attached for anyone curious
                      • lotas
                        • Jan 2016
                        • 4499
                        • Russia
                        The problem is precisely in this flash (GigaDevice 25Q41BT), it is installed in some monitors and there was a problem in the firmware, after replacing it with 25Q40 there were no problems.
                        • howardc64
                          • Jun 2017
                          • 543
                          Great info. Thanks. Will order 25Q40. Does Giga Devices or Winbond brand matter?
                          • lotas
                            • Jan 2016
                            • 4499
                            • Russia
                            Here you need to experiment, there are motherboards where there was a flash GD and after replacing it with W it did not start.
                            • howardc64
                              • Jun 2017
                              • 543
                              Thank you. I'll replace with same brand. I think I only see GD on these TCONs so far.
                              • howardc64
                                • Jun 2017
                                • 543
                                lotas There are many GD25Q40* available, most differences are previous (GD25Q40C) vs newer versions (GD25Q40E, digikey in US require min 9000 tape reel purchase) and max temperature rating (85C vs 105C vs 125C) Most easy to get is GD24Q40C 85C part. Does this matter?
                                • lotas
                                  • Jan 2016
                                  • 4499
                                  • Russia
                                  I don’t know, put a regular one, why put a high-temperature flash in T-CON.
                                  • howardc64
                                    • Jun 2017
                                    • 543
                                    Thanks. Just checking. 85C part seems good enough as you suggest
                                    • ziddey
                                      • Sep 2015
                                      • 35
                                      • usa
                                      For what it's worth, I've been using the tv with the original reflashed tcon board just about daily since I made this point, so almost 3 years now. TV has taken multiple roku updates without issue, although I imagine there probably haven't been any tcon updates, if that even was to blame originally. 25Q41BT
                                      • howardc64
                                        • Jun 2017
                                        • 543
                                        Reassuring Do you still have the failed tcon flash image? Would be interesting to compare it with the 2 failed ones I posted to see how similar.
                                        • TerraPhantm
                                          Sony A8H to A80J mainboard upgrade possible?
                                          by TerraPhantm
                                          I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
                                          So I decided I'd experiment a little bit.
                                          I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
                                          When...
                                          08-15-2023, 08:10 AM
                                        • kooroshi60
                                          Traktor Kontrol S4 MK1 Flash dump
                                          by kooroshi60
                                          Hi guys
                                          I need the Flash Dump (.bin) file of the Traktor Kontrol S4 MK1. SPI chip number is 25DF041A from Atmel (4Mbit)
                                          So please let me know if you have the .BIN Dump of this model and its price and the payment method.
                                          I appreciate your help.
                                          10-01-2024, 10:17 AM
                                        • nordlicht
                                          ThinkPad X1 Nano (20UN) bricked
                                          by nordlicht
                                          Hi guys,
                                          while trying to mod my ThinkPad X1 Nano (model 20UN) I got too impatient to hold the wires pressed to the SPI Flash contacts, so I soldered wires to it, but wasn't paying attention when connecting my programmer and, stupidly, swapped VCC and GND. Thus I fried the main SPI Flash, and I only have an incomplete/corrupt dump (u49_incomplete.bin). The secondary SPI flash on the board (W25Q256JVEIQ) seems to hold two redundant copies of the EC firmware (at 0x1000 and 0xc0000) as well as a redundant BIOS copy. I am fairly confident that the secondary Flash dump is correct (dumped...
                                          04-27-2022, 12:46 PM
                                        • bamdad61
                                          Canon DR-1210C flash dump request
                                          by bamdad61
                                          Dear folks, recently got a canon dr-1210c and it worked perfectly just for one day. Right now it shows all possible errors on the screen and do nothing. I tear down the device and found a 32 pin plcc flash chip. I thought reprogramming firmware might be helpful. The firmware update file from canon support include a dll file which doesn't help. So if anyone has the dump it would such a great favor to share.
                                          04-15-2025, 02:43 PM
                                        • EGUG
                                          Bios Dump for Fujitsu Esprimo D7010n with Mainboard D3823-A2 required
                                          by EGUG
                                          I have a Fujitsu PC with defective bios after bios update from Windows. Therfore I need a bios dump to fix it.
                                          Serial number EICK023345
                                          Mainboard D3823-A2
                                          Hope somebody can help me.
                                          04-10-2025, 02:05 AM
