TCL 55P607 / 55P605 tcon dump
googled "25Q40 corruption" This TCL TCON isn't a unique case. Samsungs and some monitors also have failures as lotus mentioned. Found the attached document on NOR flash power up down sequence.
I guess its easy to expect these NOR flashes are simple non volatile storage devices. But in reality, its quite complex. Physics of storage mechanisms of storage devices are inheriently analog and often in the realm of quantum mechanics as designs aim to get more bits / area. These NOR flash, have pre-stored parameters called "configuration settings" that are loaded into internal registers during power up to start the device. These configuration settings include many manufacturing details including yield improvements (substituting random bad blocks from manufacturing with spares) and other manufacturing varying characteristics of analog devices manufacturing.
Document details out the proper voltage power supply sequence during power up, shutdown, brown outs etc. If not properly handled, can cause error during this initial "configuration settings" transfer to internal registers which then can result in stored data bit filps. The complexity involved seems quite high for a simple TV board designs to include all the cases.
Anyway, maybe power sequence of the TCON isn't robust enough for this complex device and encounter this error at a low random frequency. Maybe newer version of 25Q40 is more robust at handling less robust power sequences as designs improved over time to handle problems observed in the field. Probably need NOR flash design experts to have any real insight.
https://www.renesas.com/en/document/...-bO6Dr4Nzn8ZTRLast edited by howardc64; 06-25-2025, 08:00 PM.Comment
your bad.bin compared to my 2 bad dumps differ by only 2 bits. So these corruptions are happening in a very similar way.Last edited by howardc64; 06-25-2025, 07:57 PM.Comment
Found datasheets for GD25Q41BT and GD25Q40C*, can't tell much differences. Here are some info
Datasheets
https://www.alldatasheet.com/datashe.../GD25Q41B.html
https://www.gigadevice.com/product/f...flash/gd25q40c
Decoding Chip Markings
(pg 46-41 of GD25Q41B datahseet)
Q = 2.7-3.7V
40/41 = 4Mbit
B/C = Revision
T = SOP8 150mil (package spec)
Datasheet Dates
Data sheet revision history of GD25Q40C* shows initial date of 2/3/2016 (pg 63) which is before manufacturing date of these TCL TVs (2017) with this TCON board. So these 2 NOR flash is likely substantially the same spec wise.
Data Retention Lifetime
GD25Q40C datasheet feature set (pg 4) does say 20 year data retention typical. So maybe its good to replace the flash that is near 50% of its typical data retention duration. The GD25Q41BT in a 2017 TCL TCON would be 8 years old now while a new GD25Q40C is presumably much younger and with different semiconductor fabrication chacteristics.Comment
by TerraPhantmI have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
So I decided I'd experiment a little bit.
I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
When... -
by kooroshi60Hi guys
I need the Flash Dump (.bin) file of the Traktor Kontrol S4 MK1. SPI chip number is 25DF041A from Atmel (4Mbit)
So please let me know if you have the .BIN Dump of this model and its price and the payment method.
I appreciate your help.-
by nordlichtHi guys,
while trying to mod my ThinkPad X1 Nano (model 20UN) I got too impatient to hold the wires pressed to the SPI Flash contacts, so I soldered wires to it, but wasn't paying attention when connecting my programmer and, stupidly, swapped VCC and GND. Thus I fried the main SPI Flash, and I only have an incomplete/corrupt dump (u49_incomplete.bin). The secondary SPI flash on the board (W25Q256JVEIQ) seems to hold two redundant copies of the EC firmware (at 0x1000 and 0xc0000) as well as a redundant BIOS copy. I am fairly confident that the secondary Flash dump is correct (dumped...-
Channel: BIOS Requests ONLY!
by bamdad61Dear folks, recently got a canon dr-1210c and it worked perfectly just for one day. Right now it shows all possible errors on the screen and do nothing. I tear down the device and found a 32 pin plcc flash chip. I thought reprogramming firmware might be helpful. The firmware update file from canon support include a dll file which doesn't help. So if anyone has the dump it would such a great favor to share.04-15-2025, 02:43 PM
by EGUGI have a Fujitsu PC with defective bios after bios update from Windows. Therfore I need a bios dump to fix it.
Fujitsu Esprimo D7010n
Serial number EICK023345
Mainboard D3823-A2
Hope somebody can help me.-
- Loading...
