Backlight 50HYT62U
  • TheBugger70
    • Nov 2021
    • 10
    Backlight 50HYT62U
    hi trying fix cousins tv with no backlight tv is hitachi 50hyt62u i beleve the power suply is vistel 17ips20. i checked power coming out the boared to leds and was getting meter jumping from around 2v to 9v so i disconected leds from bored and was still getting the same. i tryed testing the leds wen unpluged from bored but wasnt able to get any reading. im wondering if the power detects that the led's have failed it wont put the rite power out or if it is a fault with power bored is it posable to test the leds with multimeter the way i tryed by disconecting from power supply and testing from the conector rather than strip screen. thanx for any help
  • Diah
    • Feb 2013
    • 6545
    Re: Backlight 50HYT62U
    so is this mean you have approved you can see picture with tourchlight and can hear sound?? if yes .. ready yours metter on LED+ and LED- then plug the TV in wall see the reading going high and then down?
    • TheBugger70
      • Nov 2021
      • 10
      yes iv checked seen i have picture, i tested power been sent to leds its low gose from 2v to 9v jumping back nd forth it dont get high as id xpect to power the leds. but i wasnt sure if sent low power 1st then if leds were ok give the rite voltage. i tryed test the leds with multimeeter but got no reading i would of though when unpluged from power suply and tested i would of had some reading and was thincking it may be leds. thanx fr reply
      • Diah
        • Feb 2013
        • 6545
        show us high resolution focused photos of the area of the LED socket on PSU from top and down side.. by go Advanced and upload over here.
        • TheBugger70
          • Nov 2021
          • 10
          will get pics done now be 5 or so mins
          • TheBugger70
            • Nov 2021
            • 10
            think ive got pics done was stuck how to upload them
            • Diah
              • Feb 2013
              • 6545
              messure black probe on tv chassis and the red on pin 1 of socket cn501. then plug in wall.
              BTW LED socket should in place
              • TheBugger70
                • Nov 2021
                • 10
                i done that erlyer i got reding jumping between 2v - 9v i wil try get vid nd post it. sory took awhile to get back hata nip shops. dont think i can upload video of reading but it jumps from 2 to 9v back and forth
                • Diah
                  • Feb 2013
                  • 6545
                  the red wire of LED it look touching the Tv chassis..??
                  this is the schematic of the PCB see page 3 and follow voltage of LED VCC.. tell where you can find V.
                  • TheBugger70
                    • Nov 2021
                    • 10
                    the wires are just short of a inch away from the bored its just the way looks on pic. thanx will have look at that now and see what can work out
                    • Diah
                      • Feb 2013
                      • 6545
                      BTW did you messure the pin on the socket which connected with MB. BL-ON-Off are high or low while Tv powered on??
                      • TheBugger70
                        • Nov 2021
                        • 10
                        i checked for voltage while tv was on with led pluged in and with out led pluged in i got the same jumping from 2 to 9v im not sure what you mean high low, im trying to work scmatic u sent out gona go prod about with meeter just trying to understand scmatic lol. thanx fr help
                        • Diah
                          • Feb 2013
                          • 6545
                          not this what i mean.. the socket which connected between main boards and power boards pin 5 labled as BL_ON-OFF this is signal from Main boiards to turn on the backlight on and off.. messure it with ref to tv chassis .. we want to know that MB send this signal or not
                          • TheBugger70
                            • Nov 2021
                            • 10
                            ok il find and test that now
                            • R_J
                              • 9623
                              Connect your meter between ground and pin1 of cn501 (The RED wire) then plug in and turn on the tv. This voltage should jump to 80v or higher and if there is a fault it will drop to 24v
                              The picture in post #8 shows you checking pin7 (black wire) which is the led return.
                              • Diah
                                • Feb 2013
                                • 6545
                                good point... i asked him this early at post#7 ... he messure led- to chassis... lol
                                also on the photo i can see black burn close to the red wire socket
                                  • 12328
                                  • U.S.
                                  maybe unplug the backlights and see if there's stable voltages on powerboard if not tried yet.
                                  • cheeky2
                                    • Dec 2012
                                    • 339
                                    A small point but the output lead from the power supply feeding the leds you will find that the red wire on Vestel TV's are -ve and the black wire is +ve!
                                    I don't know why Vestel did this but that's probably why you are also getting low voltage. Bizzare but true!
                                    So connect the black meter wire to chassis and the red wire of the meter to the black wire coming out from the PSU. Making sure you have set meter to dc voltage!
                                    If you don't get a voltage of around 120V plus then connect red and black leads to the output connector from the psu.
                                    • pni
                                      Backlight panel diffuser melt by backlight leds broken
                                      by pni
                                      Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                                      10-12-2025, 12:08 AM
                                    • triplefour
                                      by triplefour
                                      09-13-2023, 10:43 PM
                                    • hollox123
                                      ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                      by hollox123
                                      Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                      1. Laptop keyboard doesn't work
                                      2. The backlight on the laptop keyboard doesn't work
                                      3. The x2 side LEDs (red) on the laptop don't work
                                      The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                      I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                      But I am strongly aiming that it is somehow a BIOS-related problem,...
                                      05-11-2025, 08:05 AM
                                    • signal.quest
                                      Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                      by signal.quest
                                      I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                      03-17-2024, 10:14 AM
                                    • DanPoka
                                      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                      by DanPoka
                                      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                      02-15-2025, 05:05 AM
