Backlight 50HYT62U
  • TheBugger70
    • Nov 2021
    • 10
    Backlight 50HYT62U
    hi trying fix cousins tv with no backlight tv is hitachi 50hyt62u i beleve the power suply is vistel 17ips20. i checked power coming out the boared to leds and was getting meter jumping from around 2v to 9v so i disconected leds from bored and was still getting the same. i tryed testing the leds wen unpluged from bored but wasnt able to get any reading. im wondering if the power detects that the led's have failed it wont put the rite power out or if it is a fault with power bored is it posable to test the leds with multimeter the way i tryed by disconecting from power supply and testing from the conector rather than strip screen. thanx for any help
  • Diah
    • Feb 2013
    • 6365
    Re: Backlight 50HYT62U
    so is this mean you have approved you can see picture with tourchlight and can hear sound?? if yes .. ready yours metter on LED+ and LED- then plug the TV in wall see the reading going high and then down?
    • TheBugger70
      • Nov 2021
      • 10
      yes iv checked seen i have picture, i tested power been sent to leds its low gose from 2v to 9v jumping back nd forth it dont get high as id xpect to power the leds. but i wasnt sure if sent low power 1st then if leds were ok give the rite voltage. i tryed test the leds with multimeeter but got no reading i would of though when unpluged from power suply and tested i would of had some reading and was thincking it may be leds. thanx fr reply
      • Diah
        • Feb 2013
        • 6365
        show us high resolution focused photos of the area of the LED socket on PSU from top and down side.. by go Advanced and upload over here.
        • TheBugger70
          • Nov 2021
          • 10
          will get pics done now be 5 or so mins
          • TheBugger70
            • Nov 2021
            • 10
            think ive got pics done was stuck how to upload them
            • Diah
              • Feb 2013
              • 6365
              messure black probe on tv chassis and the red on pin 1 of socket cn501. then plug in wall.
              BTW LED socket should in place
              • TheBugger70
                • Nov 2021
                • 10
                i done that erlyer i got reding jumping between 2v - 9v i wil try get vid nd post it. sory took awhile to get back hata nip shops. dont think i can upload video of reading but it jumps from 2 to 9v back and forth
                • Diah
                  • Feb 2013
                  • 6365
                  the red wire of LED it look touching the Tv chassis..??
                  this is the schematic of the PCB see page 3 and follow voltage of LED VCC.. tell where you can find V.
                  • TheBugger70
                    • Nov 2021
                    • 10
                    the wires are just short of a inch away from the bored its just the way looks on pic. thanx will have look at that now and see what can work out
                    • Diah
                      • Feb 2013
                      • 6365
                      BTW did you messure the pin on the socket which connected with MB. BL-ON-Off are high or low while Tv powered on??
                      • TheBugger70
                        • Nov 2021
                        • 10
                        i checked for voltage while tv was on with led pluged in and with out led pluged in i got the same jumping from 2 to 9v im not sure what you mean high low, im trying to work scmatic u sent out gona go prod about with meeter just trying to understand scmatic lol. thanx fr help
                        • Diah
                          • Feb 2013
                          • 6365
                          not this what i mean.. the socket which connected between main boards and power boards pin 5 labled as BL_ON-OFF this is signal from Main boiards to turn on the backlight on and off.. messure it with ref to tv chassis .. we want to know that MB send this signal or not
                          • TheBugger70
                            • Nov 2021
                            • 10
                            ok il find and test that now
                            • R_J
                              • 9535
                              Connect your meter between ground and pin1 of cn501 (The RED wire) then plug in and turn on the tv. This voltage should jump to 80v or higher and if there is a fault it will drop to 24v
                              The picture in post #8 shows you checking pin7 (black wire) which is the led return.
                              • Diah
                                • Feb 2013
                                • 6365
                                good point... i asked him this early at post#7 ... he messure led- to chassis... lol
                                also on the photo i can see black burn close to the red wire socket
                                  • 12178
                                  • U.S.
                                  maybe unplug the backlights and see if there's stable voltages on powerboard if not tried yet.
                                  • cheeky2
                                    • Dec 2012
                                    • 337
                                    A small point but the output lead from the power supply feeding the leds you will find that the red wire on Vestel TV's are -ve and the black wire is +ve!
                                    I don't know why Vestel did this but that's probably why you are also getting low voltage. Bizzare but true!
                                    So connect the black meter wire to chassis and the red wire of the meter to the black wire coming out from the PSU. Making sure you have set meter to dc voltage!
                                    If you don't get a voltage of around 120V plus then connect red and black leads to the output connector from the psu.
                                    • Pipolups
                                      Corsair K70 LUX RGB dying LEDs
                                      by Pipolups
                                      Hi there !
                                      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                      10-08-2024, 11:58 AM
                                    • THE GTC
                                      Insignia NS-37D20SNA14 intermittent LEDs
                                      by THE GTC
                                      So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                                      When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                                      11-03-2020, 02:40 AM
                                    • VitalComputing
                                      Replacing Mode Indicator LEDs
                                      by VitalComputing
                                      I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
                                      I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
                                      I thought I could just put a resistor...
                                      09-17-2023, 04:43 PM
                                    • jimbofz
                                      just a quick question do all qled leds appear blue when fault finding ?
                                      by jimbofz
                                      i have replaced many leds strips that have changed blue when they are worn
                                      and the new replacements are perfect white
                                      but when fault finding do quantum leds always look blue?
                                      08-28-2024, 06:51 AM
                                    • Quantum IC
                                      LEDs for TV Backligth
                                      by Quantum IC
                                      Hello everyone
                                      I'm new to LED strip LED replacement.
                                      The original LED comes with a single internal LED or chip. I only get at the moment LEDs with two internal LEDs or chips.
                                      I understand that this is due to the tone of the light they emit.
                                      My Doubt is:
                                      Can I use the LED with two internal chips without problem?
                                      Will there be much difference in the picture?
                                      I'm going to replace all the LEDs.
                                      Both LEDs (original and replacement) are 3V and the same size....
                                      03-04-2022, 04:03 PM
