Sony Bravia KDL-70W850B T-CON board / software update issue
  • shahnld
    • Nov 2019
    • 164
    • Netherlands
    Good Day.
    I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
    i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
    renaming, in original state nothing helps. any idea's which may help is welcome..
    cheers
    • nomoresonys
      • 12283
      • U.S.
      Try using a 4gb or less drive, Nick knows the procedure: https://www.youtube.com/watch?v=3kYPjIHt8Lc
      • shahnld
        • Nov 2019
        • 164
        • Netherlands
        Wel. As you can see in the video. His downloaded file is a .PKG file. not a zip file after extraction. This is the issue. When i extract the file for my tv. i dont get a .pkg but again a .zip with multiple files in there.
        I have also contacted nick and sad enough no clear anwser from them only suggested download from sony site which i end up again with .zip firmware.
        • nomoresonys
          • 12283
          • U.S.
          Are you sure you are getting the proper software? from what I see it was taken off 01/30/2022
          • shahnld
            • Nov 2019
            • 164
            • Netherlands
            If you mean the one in video then that is not my tv. My set is kd-65xg9505,. and all i can see is .zip on sony site for this model.. So yes i am downloading the right firmware but that is not .pkg.
            • nomoresonys
              • 12283
              • U.S.
              #26
              Ok, did you do this, when you see that second zip file, that is the one you want to put on your thumb drive, try that it should work.
              • shahnld
                • Nov 2019
                • 164
                • Netherlands
                #27
                Oh mate.. think of anything possible doing with that file and i have done that. 1st file. 2nd file. even 2nd file extracted, renamed, i have tried more than 100 times with 10 different usb sticks in different ways.. pfff. non helped. .pkg is the only way for it to work same like a windows bootle usb/disk can start the setup. putting extraced windows or iso or .zip will never boot for setup..
                .zip work only when the tv is working and you want to update its firmware then you access it with the tv menu and run it..
                It will never start the update from a usb port on its own.
                • nomoresonys
                  • 12283
                  • U.S.
                  #28
                  Well hell if I know, that's a strange one, the procedure is there: https://www.sony.co.uk/electronics/s...tware/00267389
                  • nomoresonys
                    • 12283
                    • U.S.
                    #29
                    If Nick couldn't help you then I doubt any one can, he knows sonys from front to back.
                    • shahnld
                      • Nov 2019
                      • 164
                      • Netherlands
                      #30
                      wel. he just did not provided the firmware. otherwise there is no further issue with the tv..
                      • x_orange90_x
                        TCL 50S535 bad tcon or panel issue?
                        by x_orange90_x
                        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                        03-29-2025, 11:02 PM
                      • thelankanguy
                        Sony KD-55X9000F TCON Issue
                        by thelankanguy
                        The TV shows a black screen with no image.
                        TCON ribbon connectors were disconnected individually for image and there was no half image even.
                        Later both ribbons were disconnected and TCON voltages were tested.
                        12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                        There is also a short to ground in this circled inductor.
                        Is this a TCON issue or something else ?...
                        12-13-2024, 12:27 AM
                      • cagri
                        BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
                        by cagri
                        I have an Arcelik TV with BOE HV650QUB-F70 TCON board, but I think there's an issue with/around PMIC.
                        PMIC: iML8940
                        There is backlight and sound, but no picture. I watched a YouTube video and turned it off, half an hour later it was dead.
                        Input 12v, fuse ok
                        DVDD1V2 = 1.2v
                        DVDD1V8 = 1.8v
                        DVDD3V3 = 3.3v
                        VGL = -7v
                        **VGH = -0.3v
                        **VCOM0, AVDD, HAVDD = 0v
                        SWBK1 = 3.3v
                        SW1 = 12v
                        VGH to GND resistance is 500kohm as expected
                        Readings are same after I disconnected the two cables from TCON to panel...
                        07-27-2023, 09:48 PM
                      • T4-BR
                        T470S - TPM issue since TPM/BIOS update from Windows Update
                        by T4-BR
                        Many thanks for the high quality ressources available on your website.
                        I'm currently facing some issues with my T470S:
                        - I sat a Supervisor Password using special chars which was causing issues
                        - Access to BIOS was locked but I was still able to use my PC
                        2 weeks ago, I got an update of BIOS/TPM from Windows Update.
                        Computer restarted and after Lenovo logo a loading bar appeared and at the end something went wrong + an error popped.
                        Computer restarted one more time and I got the prompt for typing Bitlocker...
                        09-26-2024, 02:50 AM
                      • ahmypc
                        Microsoft Surface Pro 4 Bios Update Issue
                        by ahmypc
                        The device that has not received an update for a long time cannot update the new ME Region. That's why touch doesn't work. Bios file cannot be opened with Flash Image Tool. Additionally, I am attaching the update file downloaded to the device and the original bios file. I would be glad if you help....
                        09-21-2023, 02:14 AM
