LG 50PQ3000 Fixed No Standby Light
  • Ukdigger
    • May 2020
    • 121
    • England
    LG 50PQ3000
    Opened this TV and it looked like someone had emptied a hoover bag over all the boards. I cleaned all the boards front and back and noticed the main fuse on the power board had failed. I couldn't see any bad caps so I replaced the fuse and the TV worked with no problems, all voltages were good.
  • nomoresonys
    • 12269
    • U.S.
    Re: LG 50PQ3000 Fixed No Standby Light
    I try to blow the dust out of all my electronics about once a month with my shopvac.
    • ChristianBr01
      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
      by ChristianBr01
      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
      04-23-2025, 01:48 AM
    • brithepi2k
      Sony KD-65XE8596 no standby light
      by brithepi2k
      I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
      cheers...
      09-06-2025, 02:22 PM
    • AleMonti
      LG 55EG910V - no power and no standby light
      by AleMonti
      I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
      I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
      The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
      After checking the basics I did the following:
      • I measured all voltages and as expected the only active supply is the 3.5V standby. It
      11-04-2024, 05:02 PM
    • Kaar3l
      Samsung QLED QE65Q7FNAT only standby light
      by Kaar3l
      TV: Samsung QLED QE65Q7FNAT
      PSU: BN4400940A
      MB: BN94-12832K
      I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
      09-24-2024, 01:35 PM
    • jasonbay13
      Philips 37HFL5682L/F7 no standby light, incomplete service manual?
      by jasonbay13
      picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
      am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
      12-01-2023, 09:55 PM
