Sony XBR-49X900E - is this salvageable?
  • griesemaster
    • May 2022
    • 5
    I obtained a Sony XBR-49X900E with the following behavior:
    -Powers on
    -No Smart Core led code
    -Backlight on when TV powered
    -Display shows breathing/moving green blobs on a black background
    Using the service manual, I decided to replace the TCON and see any changes. After replacing TCON the following behavior presented itself:
    -Powers on
    -Smart Core alternating orange/green pattern infinitely
    -Display fully black
    Following some threads I found here, I tested the following options.
    -Disconnecting the TCON from main board resulted in static vertical color strips on display
    -Attempting to flash firmware via usb was non-responsive (unable to verify any changes due to lack of display)
    Here is where the title question comes into play and my major failure. I attempted to check power to the TCON and either misread the service manual or was sloppy with my probes. When checking, I definitely bridged something, caused a spark and likely damaged some other components. The following behavior now presents itself:
    -Powers on
    -Display black when TCON connected
    -Display no longer shows vertical color blocks when TCON disconnected
    My intuition tells me I murdered the main board, which is causing the lack of color blocks when TCON disconnected. My main concern is that I killed the panel which would make any repair basically impossible. Any assistance in deciding future steps, advice, or general knowledge is greatly appreciated. First time repairing TVs so this has been a fun experience, but my overconfidence may have killed me.
    • 12196
    • U.S.
    Re: Sony XBR-49X900E - is this salvageable?
    see if you have 12 volts on each side of tcon fuse, neg probe on chassis ground.
      • 12196
      • U.S.
      can you post good clear straight on pictures of each board, one of the whole back to see how everything is connected and a close up of exactly where you were testing when you had the mishap.
        • 12196
        • U.S.
        if you can get back to alternating orange/green pattern, Nick's has some methods here to try: https://www.youtube.com/watch?v=3kYPjIHt8Lc
          • 12196
          • U.S.
          this is probably the worse model to have to deal with for your first try, hope you have luck with it.
            • 12196
            • U.S.
            check the bl-err pin on the powerboard connector, check it in standby[tv plugged in but off] and check it with tv powered up, what do you get? black neg. probe on chassis ground pos. probe on bl-err pin.
            • griesemaster
              • May 2022
              • 5
              Both the new and original TCON have 0.06v on either side of the fuse when I tested just now
              • griesemaster
                • May 2022
                • 5
                Here are all the photos. I did my test on the connecting block out of the power board, trying to hit the bottom lead, which I think is TCON_VCC12V from the manual. After looking at this again, I think I may have just bridged the 12v to the next door ground.
                • griesemaster
                  • May 2022
                  • 5
                  Could you give more direction on where to locate the pin?
                    • 12196
                    • U.S.
                    • Daren87
                      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                      by Daren87
                      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                      08-13-2023, 03:25 PM
                    • thelankanguy
                      Sony KD-55X9000F TCON Issue
                      by thelankanguy
                      The TV shows a black screen with no image.
                      TCON ribbon connectors were disconnected individually for image and there was no half image even.
                      Later both ribbons were disconnected and TCON voltages were tested.
                      12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                      There is also a short to ground in this circled inductor.
                      Is this a TCON issue or something else ?...
                      12-13-2024, 12:27 AM
                    • bbrain
                      Sony KD-55AG9 TCON?
                      by bbrain
                      I have this problem with my Sony 55' AG9.
                      It flashes 4x.
                      I have found the service manual, and seems it is the TCON.
                      Before I buy a TCON can someone check the vid?
                      Thanks in advance!...
                      09-19-2024, 10:50 AM
                    • rimwall
                      Sony KD-65x8500b - bad Tcon or panel?
                      by rimwall
                      Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                      a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                      b) the Tcon board is malfunctioning,...
                      10-24-2023, 07:58 PM
                    • x_orange90_x
                      TCL 50S535 bad tcon or panel issue?
                      by x_orange90_x
                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                      03-29-2025, 11:02 PM
