Samsung 3DTV UE46EH6030 fault
  • josweet
    • Nov 2015
    • 17
    The psu is a BN44-00552A.
    The Tv hasnt been used a while and only had light usage when bought.
    The Fault>
    The Tv works perfectly when first powered up, however after about 10=50mins,
    it shuts down the repeatedly reboots its self. When left for a time, its works again for another 10-15mins
    Im not a high end engineer so the basics only were checked.
    I figured it was a heat related fault which possibly stemmed from either a
    a dry joint or swollen caps, both of which look good visually on the PSU
    Any help gratefully appreciated.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Samsung 3DTV UE46EH6030 fault
    You could try re soldering all parts that are mounted on the heatsinks also the large transformers even if joints look ok i would reheat and add some fresh solder.
    The capacitors may look ok but could really do with being tested with a esr meter.
    • josweet
      • Nov 2015
      • 17
      Im looking at Capacitance meter's now. A Smart meter would be better for me as a good all rounder.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        I have a few esr testers this is the main one i use
        https://www.ebay.co.uk/itm/353680931...Cclp%3A2047675
        Just remember to make sure capacitors are discharged before testing as will blow parts in the meters
        • nomoresonys
          • 12184
          • U.S.
          +10, look those solder joins over very closely.
          • nomoresonys
            • 12184
            • U.S.
            examples of bad joints, for those looking on who may need it: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
            • josweet
              • Nov 2015
              • 17
              Quick update>
              Spent some time going over the board with the soldering iron, covering anything that looked slightly suspicious.
              Put the TV back together and fired it up. ....
              So far it been running for the past 2.5hrs with no problems at all.
              Ill still soak test it as its frustrating not knowing exactly what the fault is/was, but for now looks like it possibly fixed.
              Thank you to everyone for your help.
              Side note > this is what i is the Smart meter i was looking at > https://www.aliexpress.com/item/1005...c00gZnwdo&mp=1
              • dskall
                • Oct 2016
                • 2905
                • usa
                You can also take a hair dryer and go around to see if tv fails at certain spot. It may very well been a bad solder joint though.
                • josweet
                  • Nov 2015
                  • 17
                  @dskall
                  Thats a good idea.
                  ill see how it goes over the next few days as looks like it maybe fixed now.
                  No way of knowing for sure without soak testing it.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    Originally posted by josweet
                    Quick update>
                    Samsungs seem to suffer from dry joints but if you resoldered any capacitors it may of altered the esr tempory with the heat from soldering.
                    That looks a good meter but cant see it mentioning esr testing.
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
                      09-07-2024, 05:50 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
