43pus6401/12 - no picture, blinking ambi lights
  • domix
    • Jan 2014
    • 166
    • Slovenia
    Hello i have 43pus6401/12.
    After turn on red light slowly blinking and ambilight blinking randomly, different colors fadein/out, etc
    Screen is black, no backlight. Caps look normal. I didnt measure it, I forgot my multimeter in another car.
    Any common issue?
  • domix
    • Jan 2014
    • 166
    • Slovenia
    Re: 43pus6401/12 - no picture, blinking ambi lights
    Vled pins shows all as it should be okey. What elae to check? Is mybe firmware?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Firmware or cpu fault, these Phillips boards are trash.
      https://youtu.be/BD4J1JQcB7A
      • domix
        • Jan 2014
        • 166
        • Slovenia
        New working board from ebay will work ?
        • William1967
          • Nov 2017
          • 206
          • Netherlands
          Replace led strips when you have no backlight and there is ambilight. When you take a good look when the tv starts up you will see a dark Philips logo in the middle of the display.
          • bialag
            Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
            by bialag
            I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
            Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
            03-25-2025, 05:56 PM
          • Audeze
            Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
            by Audeze
            I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
            Does...
            10-06-2024, 08:54 PM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • dominik0801
            Philips 55PFL6008K/12K Ambilight not working
            by dominik0801
            Hey,
            I just got the TV mentioned in the title the other day.
            Yes, I am well aware of it being a QFU chassis which is very hated - although I love QFUs (maybe for being this bad?), my main TV is a QFU too, and I bought this TV for this very reason.
            It had the typical 2 blink error, which was fixed by a proper Fusion CPU reballing, with extra cooling mods. It works.
            Everything is perfectly fine with it, but the Ambilight just won't do anything.
            At all.
            Won't work on Dynamic, won't work on Static. Not a single...
            11-28-2022, 01:24 PM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
