RCA RLCDV3282A-B LCD power off and on every few minutes
  • rookiecap
    • May 2022
    • 6
    I have a LCD combo tv model RCA RLCDV3282A-B, and it broke down. The symptoms were
    [1] very low volume
    [2] flickerring image proportional to sound and brightness
    [3] the power turns off and on every few minutes
    So I took it apart and looked at the power board. I found some swollen capacitors. So I replaced all electrolytic capacitors (14 of them) according to their original specs.
    Unfortunately it did not fixed all problems. I have a the volume and no more flickering (good image). However, the power turns off and on every few minutes randomly.
    What I am missing? What are my next steps?
    Last edited by SMDFlea; 05-16-2022, 12:42 PM. Reason: Added "RCA RLCDV3282A-B" to thread title
  • nomoresonys
    • 12097
    • U.S.
    Re: RCA RLCDV3282A-B LCD power off and on every few minutes
    might be a solder joint problem, recheck your work and check all other solder joints.
    • nomoresonys
      • 12097
      • U.S.
      some examples of bad joints: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
      • dskall
        • Oct 2016
        • 2905
        • usa
        Next step is pictures
        • rookiecap
          • May 2022
          • 6
          For all of the replies, thank you. I am attaching pcb board images. I accept criticism with no hard feelings.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Can't see your connector pin out. Need to check your voltages on connector to mainboard.
            • nomoresonys
              • 12097
              • U.S.
              recheck your work and make sure that and ALL the other solder joints are good.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
                09-06-2024, 05:59 AM
                HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-12-2024, 02:15 PM
              • meraklinetx
                Asus Z97-a power cycle, no boot no cpu voltage
                by meraklinetx
                Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                05-10-2023, 06:08 AM
