samsung tv ue43ru7400u dark screen problem help
    • 12129
    • U.S.
    Re: samsung tv ue43ru7400u dark screen problem help
    READ READ post #18 DO TEST.
    • garysnooker
      • May 2022
      • 14
      Hi this a edge lit Tv can i still do that test in #18 thanks for your help
        • 12129
        • U.S.
        Yes.
          • 12129
          • U.S.
          easy test, make sure the tv is unplugged from power, unhook cable from powerboard to mainboard, plug power cord into powerboard, plug into outlet,
          see if backlights come on and stay on, always make cable connections with tv unplugged from power to avoid and errant surges that could happen.
          • garysnooker
            • May 2022
            • 14
            ok thanks i wiil give it a go
            • garysnooker
              • May 2022
              • 14
              #26
              Hi there is only one power lead coming from the powerboard and its going to the mainboard so when i disconnect the lead there is no power going to anythink
              • lotas
                • Jan 2016
                • 4562
                • Russia
                #27
                Why only one, you have two cables connected 1 - main, 2 - led.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #28
                  If that doesn't work, you can monitor led voltage. If voltage is stable, then it's probably not backlights.
                    • 12129
                    • U.S.
                    #29
                    it's cnm801 connector, unhook the cable at that connector to try that test.
                      • 12129
                      • U.S.
                      #30
                      the power comes from the power cord that you plug back into the powerboard.
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
                      • mmccomputer
                        problem with replacing lcd screen
                        by mmccomputer
                        I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                        otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                        If anyone has any information on the subject...
                        12-15-2024, 03:44 PM
                      • Chrissygizmo
                        samsung galaxy ao2s very temperamental after screen replaced
                        by Chrissygizmo
                        Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                        Ive eventually managed to get it on and working but it's very temperamental...
                        The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                        05-26-2024, 12:05 AM
                      • jimjoe123
                        LCD TV Green/Pink screen problem
                        by jimjoe123
                        I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                        Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                        Then each time...
                        02-23-2020, 01:29 AM
                      • CityZen
                        Samsung un48ju6700 half screen ghosting problem
                        by CityZen
                        This curved LCD TV has an issue affecting just the right side of the screen. It is not a backlight issue, although it might appear so from one of the attached images. The problem appears to be the right side of the screen not updating properly. Moving images on the very right side will leave a trail of ghost images. Although even just the computer cursor sitting still makes a vertical ghost band the entire height of the image. The color on the right side also looks like it doesn't have the full bit depth (the Windows background looked kind of dithered on that side).
                        I went into...
                        11-24-2021, 12:03 AM
