samsung tv ue43ru7400u dark screen problem help
  • garysnooker
    • May 2022
    • 14
    Hi its like the brightness is trun right down ive reset the TV.help
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: samsung tv ue43ru7400u dark screen problem help
    Some pictures of the problem would be nice.
    • garysnooker
      • May 2022
      • 14
      its to dark for pictures
      • dskall
        • Oct 2016
        • 2905
        • usa
        Bad backlights.
        • garysnooker
          • May 2022
          • 14
          is that a big job
          • garysnooker
            • May 2022
            • 14
            there is a Picture but it is dark
            • dskall
              • Oct 2016
              • 2905
              • usa
              Sorry your giving little to go on, but my tv is dark, what's wrong.
              • garysnooker
                • May 2022
                • 14
                Hi is there a way i can test the backlights.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Is your screen uniformly dark?
                    • 12141
                    • U.S.
                    • garysnooker
                      • May 2022
                      • 14
                      Hi yes it is
                        • 12141
                        • U.S.
                        nevermind, too much trouble trying to help, when simple instructions are not followed.
                        • garysnooker
                          • May 2022
                          • 14
                          working blind here without pictures.
                          will do pictures.tomorrow
                          • brucetv
                            • May 2015
                            • 281
                            • united states
                            Most likely you have a short in the backlight bars since this is a edge lit Tv. Alot of times is actually melts the diffuser and will leave light bleed on the bottom where the leds got too hot after you replace the led bars and you can't buy new diffusers so is it worth repairing? Not on that size Tv. You have to pull the panel just to get to the backlights and if the diffuser is melted there is no use in replacing them because they are just going to leave light bleed across the bottom of the panel which looks like crap. Samsung quality went to hell a long time ago spending more money fighting corruption charges than on engineering.
                            • garysnooker
                              • May 2022
                              • 14
                              thanks for your help on this im going to take it apart and have a look at it nothing to lose
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                This thread is worth a read
                                https://www.badcaps.net/forum/showth...=samsung+burnt
                                • garysnooker
                                  • May 2022
                                  • 14
                                  Hi is there a way of testing the backlight before a take it apart
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    yes if you have a backlight tester,
                                    what happens if you remove the cable between mainboard and power supply do the backlights power on then?
                                    This will give you a rough idea whats involved to change backlights but remember big risk of cracking lcd panel!
                                    https://www.youtube.com/watch?v=HFi2slA4ZK8
                                    • garysnooker
                                      • May 2022
                                      • 14
                                      Hi ive just had a another look at the tv and im not to sure if it is the backlight ive made a video could some one have a look at it to see if it is the backlight https://www.youtube.com/watch?v=fJe-APbbSjE
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        I would say faulty backlights.
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • mmccomputer
                                          problem with replacing lcd screen
                                          by mmccomputer
                                          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                                          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                                          If anyone has any information on the subject...
                                          12-15-2024, 03:44 PM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
                                        • CityZen
                                          Samsung un48ju6700 half screen ghosting problem
                                          by CityZen
                                          This curved LCD TV has an issue affecting just the right side of the screen. It is not a backlight issue, although it might appear so from one of the attached images. The problem appears to be the right side of the screen not updating properly. Moving images on the very right side will leave a trail of ghost images. Although even just the computer cursor sitting still makes a vertical ghost band the entire height of the image. The color on the right side also looks like it doesn't have the full bit depth (the Windows background looked kind of dithered on that side).
                                          I went into...
                                          11-24-2021, 12:03 AM
