Adapting a samsung panel to Vestel 17MB211
  • saronno
    • Jan 2012
    • 57
    Hi, I have a telefunken tv with a broken panel (VES315WNDA-2d-n12). The tv has a 17mb211 board.
    Since I had a samsung with a good panel (df320agh-r1) I try to adapt this to the telefunken.
    Pinout was almost the same (the only thing I have to move the connect on the 17mb211 according to the image below ... from double lvds to wxga fcc).
    Panel is working bad badly. Color is wrong ... image was flip (I was able to correct this playing with ptf.ptf file ... b8HFlip = 1 b8VFlip = 1 to be precise ).
    Does any of you have any experience with vestel board and ptf.ptf file parameters?
    I attach also the ptf.ptf file ..
  • saronno
    • Jan 2012
    • 57
    Re: Adapting a samsung panel to Vestel 17MB211
    • arizanotlari
      • Nov 2014
      • 158
      • Turkiye
      Samsung HD Panel file : https://disk.yandex.com.tr/d/672hb9tqJMwcZw
      https://www.badcaps.net
      • saronno
        • Jan 2012
        • 57
        I didn't spot any difference but flip parameters. Am I right?
        to me, looking at the image, it seems as if there aer not the full range of colors, like when you setting pc video card to 8 bit or 16.
        • Diah
          • Feb 2013
          • 6422
          T-CON intgertated at Panel ?? if yes can you show here the T-CON chip so i can see it to check yours parameter
          • arizanotlari
            • Nov 2014
            • 158
            • Turkiye
            actually this problem looks like a lvds socket problem. I tried the panel software on the Samsung panel and it worked without any problems.
            • arizanotlari
              • Nov 2014
              • 158
              • Turkiye
              VES315WNDA-2d-n12 = CN16
              Samsung HD = CN15
              CN14 should not be used this chassis
              • saronno
                • Jan 2012
                • 57
                Tomorrow I will open it again to make some photos.
                • saronno
                  • Jan 2012
                  • 57
                  Samsung HD = CN15
                  Probably you are right. I move the connector a couple of week ago so I am not sure ... anyway right now it's at cn15
                  • saronno
                    • Jan 2012
                    • 57
                    You mean I should recheck cable and connectors?
                    If so, I guess it could be some problem with the tx pins
                    clock is improbable since I have a picture .... but one of the tx line could impair some specific bit in the frame if it's not working or malfunctioning.
                    • saronno
                      • Jan 2012
                      • 57
                      I didn't find the datasheet for the samsung panel I am trying to adapt to the vestel, but I find this one below I suspect have the same pinout
                      https://datasheetspdf.com/pdf-file/9...g/LTA320AN01/1
                      This is a picture of the connector of my panel
                      So, as I said, it has the same pinout of the board (CN15) but it was mirrored.
                      • arizanotlari
                        • Nov 2014
                        • 158
                        • Turkiye
                        We need picture of chassis.
                        • saronno
                          • Jan 2012
                          • 57
                          Ok, I solved. It was the connector.
                          First thing I asked to myselft "why everything is reddish" ... so in the samsung pdf
                          i posted above I checked "what if red is stuck" ... and so tx0 has to be 1 all the time .... and so I checked with my multimeter and the two line were shorted together (a little bridge under the connector not visible from above). Anyway I changed the connector completely (the old one was in bad condition after a couple of soldering/desoldering) and now everything if fine.
                          Anyway, Thanks for the help.
                          • saronno
                            • Jan 2012
                            • 57
                            Just to sum it up if everybody else want to try to adapt a samsung panel to this
                            vestel board: yes, it's possibile but be careful with the pinout since it's mirrored.
                            • howardc64
                              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                              by howardc64
                              • Prior owner tried a replacement main board. No difference.
                              • Samsung 2x red blinking standby LED = panel fault
                              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                              07-19-2025, 10:54 PM
                              09-07-2024, 05:50 AM
                            • triplefour
                              SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                              by triplefour
                              TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                              tcon is built into mainboard.
                              Only one cable goes to panel boards.
                              there is a cable from one panel board to the other that links them.
                              cost cutting measure that results in us having harder time to diagnose.
                              removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                              used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                              07-28-2022, 07:59 PM
                            • NWArkGuy
                              Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                              by NWArkGuy
                              Well, I will be the first to admit that I screwed up...
                              In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                              I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                              I have 2 that I have found and have in my possession. ...
                              10-12-2023, 10:13 PM
                            • KYBOSH
                              Samsung UN50TU8000 - Dead Panel Forensic Questions
                              by KYBOSH
                              I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                              When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                              When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                              Later I checked for shorts on the panel PCB boards but could not find anything.
                              When I took a look with the FLIR i noticed the 2 resistors...
                              08-10-2024, 08:39 AM
