Take a look at the attached pic. The whole image (not the backlight) on the screen is flickering. A ghost image will pop up above the actual image and flicker in and out rapidly and then go away for a few sec and then do it again. When this happens it affects the whole screen not just one section. The longer the TV runs the less the flickering until after about 30 mins the flickering goes away completely and the picture will be great for the rest of the time the TV stays on. So the TV running and warming up makes the problem go away. This TV only has two boards the power supply and main. The Tcon is built into the main board. Question: Is this flickering problem due to a bad Tcon section on the main board or a bad panel? thanks, Lee
Samsung UN50MU6300
Re: Samsung UN50MU6300
So the water is shorting some of the tabs? If running the TV temporarily clears the short there can't be much water there. Do u think heating the tabs with a hair dryer might fix this problem? Any ideas other than taking it to the dump?Comment
The water is probably long gone now, but it did separate the tab bonds from the panel somewhat. You can try squeezing hard around the bezel and see if the screen returns to normal. You can also disassemble the TV and put your finger on each tab bond and see which one(s) are the problem. I used to shim the problematic tab bond by using heat conductive pads or a piece of an eraser. It would last for quite a while. Nope... heating it won't fix it. All you can do is put constant pressure on it.
Nuke option: buy a new one, turn the backlights down to 75% and don't wash it!Comment
Search on Youtube. There are many tutorials. An example:
https://www.youtube.com/watch?v=6ma6UuiUg34&t=346sComment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by Asraf AtbHi everyone,
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by JSin21Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
I have Samsung Smart TV UA65MU6100WXXY version DA01
Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...4 Photos -
by shlomim412hi
having problem with samsung ua55es6800
tv had backlight on, sound working - responds to the remote control but no image.
check tcon board - had 12v in but no other voltages present.
when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
when leaving only left side connected - again no voltages and no image.
put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
kept trying to block less pins on the left ribbon cable... -
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
