Samsung UN50MU6300
  • Lee M.
    • Nov 2021
    • 35
    Samsung UN50MU6300
    Take a look at the attached pic. The whole image (not the backlight) on the screen is flickering. A ghost image will pop up above the actual image and flicker in and out rapidly and then go away for a few sec and then do it again. When this happens it affects the whole screen not just one section. The longer the TV runs the less the flickering until after about 30 mins the flickering goes away completely and the picture will be great for the rest of the time the TV stays on. So the TV running and warming up makes the problem go away. This TV only has two boards the power supply and main. The Tcon is built into the main board. Question: Is this flickering problem due to a bad Tcon section on the main board or a bad panel? thanks, Lee
  • CapLeaker
    Leaking Member
    • 8325
    Re: Samsung UN50MU6300
    Somebody washed the TV literally. The water ran into the tab bonds.
    • Lee M.
      • Nov 2021
      • 35
      So the water is shorting some of the tabs? If running the TV temporarily clears the short there can't be much water there. Do u think heating the tabs with a hair dryer might fix this problem? Any ideas other than taking it to the dump?
      • CapLeaker
        Leaking Member
        • 8325
        The water is probably long gone now, but it did separate the tab bonds from the panel somewhat. You can try squeezing hard around the bezel and see if the screen returns to normal. You can also disassemble the TV and put your finger on each tab bond and see which one(s) are the problem. I used to shim the problematic tab bond by using heat conductive pads or a piece of an eraser. It would last for quite a while. Nope... heating it won't fix it. All you can do is put constant pressure on it.
        Nuke option: buy a new one, turn the backlights down to 75% and don't wash it!
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4458
          • Italy - Milan
          I don't think this tv has got side tabs, i'ts not a washing issue but an intermittent short on a gate driver, already seen so many times, possible fix the tape method...
          • yokoono
            • Apr 2010
            • 505
            Search on Youtube. There are many tutorials. An example:
            https://www.youtube.com/watch?v=6ma6UuiUg34&t=346s
              09-07-2024, 05:50 AM
            • Asraf Atb
              by Asraf Atb
              01-27-2025, 05:02 PM
            • JSin21
              Compatibility of main boards between different variations of samsung MU6100
              by JSin21
              Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
              I have Samsung Smart TV UA65MU6100WXXY version DA01
              Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
              11-27-2023, 04:54 AM
            • shlomim412
              samsung ua55es6800 - no image
              by shlomim412
              hi
              having problem with samsung ua55es6800
              tv had backlight on, sound working - responds to the remote control but no image.
              check tcon board - had 12v in but no other voltages present.
              when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
              when leaving only left side connected - again no voltages and no image.
              put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
              kept trying to block less pins on the left ribbon cable...
              05-15-2024, 05:00 AM
            • Yanleb
              Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
              by Yanleb
              Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
              If they are not compatible why did Samsung give them the same part number to begin with?
              08-04-2025, 11:35 PM
