Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
    • 12199
    • U.S.
    #61
    Re: Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
    indeed that is reasonable, I wouldn't be surprised if the mainboard is the only problem, interesting thread, will be watching, I own a sharp lc from 2007 but it never broke, hope it don't, I don't get much opportunity to fiddle with a sharp. Seem to be good tvs tho except for the ones with the panel problems.
    • Diah
      • Feb 2013
      • 6375
      indeed that is reasonable, I wouldn't be surprised if the mainboard is the only problem, .
      you are now indeed join my 2 glass whisky with me lol
      • Diah
        • Feb 2013
        • 6375
        okay. seriously.. let finish here
        when we are testing PCB standalone and we did have the main V 12 or 13 0r 24 v. these are what MB need so we stop testing standalone , we leave it to MB to see first step starting ( eeprom ) sending PS_ON if it did and main V we find them which i mentioned before are enough
        any lack of other Panel or BL are because Main IC don't give feed back signal to eeprom so it stay blind didnt send signal to turn them on..... this is 99,9% the case over all TV platform.
        • beetle1303
          • Jul 2019
          • 279
          • Singapore
          #64
          Originally posted by beetle1303
          1) Screen ribbon cable unplugged from T-Con, power on normal - no change flashing 2x red flight
          2) While screen ribbon cable unplugged, pressed Vol- & Chn-, powered up: no change flashing 2x red light.
          Will do the oven bake tomorrow morning, then redo these various procedures.
          Thank you, and good night.
          Baking in oven at 250C 12min, off oven open door slight to cool for 20min, took out and cooled to room temperature. Man, it stink!!
          All the white plastic connector turned brown... I think the PD connector deformed and not able to get a tight-fit clicked connection anymore.
          Seems like intermittently connection problem now. On powered up -the power indicator 2x flashing sometime there sometime not. After a few hard reseat, it eventually failed and not able to get power up indicator anymore...
          And when able to get power up 2x flashing red light, did all the reset procedures: Vol- & Chn-, Vol+ & Chn-, etc. all the results are no difference from those before back, including those voltages when reset to green led light.
          So, I guess the MB is truly toasted, time to move on the get a replacement MB now.
          • Diah
            • Feb 2013
            • 6375
            so the BGA issue at main IC became more.. use hotair gun to toast the mediateck chip only... who knows could catch solder point.
            • beetle1303
              • Jul 2019
              • 279
              • Singapore
              #66
              Hmm, I don't have a heat gun.. Is a 2000w big hair-dryer good enough? Or a small butane torch safe for this?
              • beetle1303
                • Jul 2019
                • 279
                • Singapore
                #67
                Nope.. with the big 2200w hairdryer at max heat min for 6-8min, nothing happens..
                • Diah
                  • Feb 2013
                  • 6375
                  you need at least 250° only hot air gun can do,, or infrared Korean BBQ
                  • beetle1303
                    • Jul 2019
                    • 279
                    • Singapore
                    #69
                    I have a butane torch for brazing that can heat to 700°C - can use this at low frame for 1-2 minutes?
                    • Diah
                      • Feb 2013
                      • 6375
                      wow... try but could be good if you put weight on the IC and from downside start heating or from the top ab to you just to avoid the chips move from it place... be sure you know the emergency fire police Tel No,
                      • beetle1303
                        • Jul 2019
                        • 279
                        • Singapore
                        #71
                        Nope... torch with lowest frame for 1 minute or so, and stopped immediately at the sight of light smoke! No, it did not trigger fire alarm, but retested and ya, completely BBQed
                        • Diah
                          • Feb 2013
                          • 6375
                          A quick checked - the big cap shows 403Vdv but all the transformers above it shows no voltages in all the output pins... With a LED tester - all the 14 led strips are mostly 175V, with 2-3 showing 173-174V.
                          i just reading back yours POST #13 you wrote that you cant see any light of LED with tester however the tester show 173V !!
                          you dont have 14 strips from the photo i can see only 7 wires on eack socket the LED - socket L2 and LED+ socket L1
                          so forexample testing LED-2 with LED+2 LED-11 with LED+11 and so on.. you can see from amy whole at the chassus if there are light or not.
                          • beetle1303
                            • Jul 2019
                            • 279
                            • Singapore
                            #73
                            See attached pic - there are 14 LED+ and LED-
                            With LED tester red probe on LED+ and black probe on LED-, it reads 173-175V range, mostly 175V. *Cannot* see any light from the back of chassis holes, nor from the front screen.
                            *LED tester working when tested with spare led strip.
                            • beetle1303
                              • Jul 2019
                              • 279
                              • Singapore
                              #74
                              Shopping for a replacement MB:
                              This one from TaoBao is the closes I can find:
                              Model: LCD-70LX732A MB: QPWBXF733WJN2 Panel: LK695D3GW30C
                              Original:
                              LC-70LE735X MB: QPWBXF733WJN2 Panel: LK695D3GW3AD
                              You think this will work?
                                • 12199
                                • U.S.
                                #75
                                what are the 5 letter numbers on the white sticker on the original mainboard?
                                • beetle1303
                                  • Jul 2019
                                  • 279
                                  • Singapore
                                  #76
                                  This white sticker?
                                  • Diah
                                    • Feb 2013
                                    • 6375
                                    i see now each socket 14 wires.. this is monster.. yours LED tester cant turn on them as i think its limitet with currents few ma.
                                    at time yours LED BL are 420 LED
                                    in Australia there are used one MB and in Philippine too
                                      • 12199
                                      • U.S.
                                      #78
                                      yes, that must be it, if you can match those f733wek6 or f733k6, you should have a match, as far as other boards working, I don't know.
                                      • beetle1303
                                        • Jul 2019
                                        • 279
                                        • Singapore
                                        #79
                                        But I am tester each of the 14 strips individually - should be able to lit up the 30 leds in it as I have tested it on older 30-led strip.
                                        I will retry in total darkness and see if what happen.
                                        *the link to MB you provide is quite expensive... I am searching of cheaper ones from China but they seems to be of different models.
                                        • beetle1303
                                          • Jul 2019
                                          • 279
                                          • Singapore
                                          #80
                                          https://www.bukalapak.com/p/elektron...35x-lc70le735x
                                          This part link provided by Diah looks like identical to my original MB, but it's 10x more expensive the the close-look from China.
                                          I think I will try my luck with this cheap one.
                                          • Cemal Odabasioglu
                                            MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                            by Cemal Odabasioglu
                                            I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                            Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                            Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                            Observations...
                                            01-14-2025, 03:54 PM
                                          • triplefour
                                            ONN 100012588 Has fluctuating Voltage on PSU 12v
                                            by triplefour
                                            Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                                            anyway i go to this guys house to look at an ONN 100012588
                                            this is my first time looking at one of these brand of TV's.
                                            TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                                            09-14-2022, 07:41 PM
                                          • beetle1303
                                            Wine Chiller - SMPS issue - fluctuating voltages
                                            by beetle1303
                                            My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                                            Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                                            Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                                            Checking further on the primary side: Incoming line input to bridge...
                                            09-04-2023, 10:33 AM
                                          • koby058
                                            yoga9 3v3 5v fluctuating
                                            by koby058
                                            Hi
                                            board model: NM-D992
                                            type c remains on 5v. when i connect it the 3.3VALW and 5VALW fluctuating. can someone please help understand why?
                                            main power rail voltage 13v
                                            till now i have tried:
                                            measured all coils resistance looks ok
                                            replaced RT6585CGQW to a brand new one
                                            replaced all mosfets for 3.3v regulator and the dual mosfet for 5v regulator
                                            happen both on DC power and on battery
                                            issue remains
                                            video
                                            schematic attached...
                                            08-03-2025, 09:06 AM
                                          • ronelex
                                            Macbook Air A1466 Fluctuating 3v supply
                                            by ronelex
                                            Hello
                                            I got this unit with orange light but wont boot up
                                            I notice that its L7560 3.3v supply is fluctuating
                                            this is the reading I got on its PWM U7501 TPS51890A
                                            pin 4- EN1 - 0v
                                            pin 12 - EN - 3.3v Fluctuate
                                            pin 21 - EN2 - 3.3v Fluctuate
                                            pin 22 - vreg3 - 3.3v ok
                                            pin 23 - vin - 8.62V
                                            pin 29 - vreg5- 5v fluctuate
                                            I already check the power rails line in page 62 but I didn't find any short on those lines. I already tried replacing the pwm but same issue.
                                            I hope you can guide me where I can look for the fault of this...
                                            02-07-2023, 04:39 AM
