Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
    • 12312
    • U.S.
    Re: Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
    not sure but OFL seems low, could it be a voltage regulator on mainboard?
    • beetle1303
      • Jul 2019
      • 279
      • Singapore
      The OFL value is jumped from PD-15 (4.96V) with a ~800ohm resistor, not connected to MB.
        • 12312
        • U.S.
        my bad, I missed that it wasn't connected to anything in post 13.
          • 12312
          • U.S.
          T7701 and T7702 have been known to be a problem on these models, maybe check them closely.
            • 12312
            • U.S.
            maybe try heating those looks like 6 electrolytic caps there by the connector on powerboard with a hairdryer, turn on and see if it does anything different, can you trace the ofl from connector to one of those caps, maybe one of them isn't up to par, what voltages are you getting on them with powerboard jumped?
            • beetle1303
              • Jul 2019
              • 279
              • Singapore
              #26
              I am not sure how accurately I checked. With DMM in Ohm mode, both input and output side measures 1-2 ohms only. Both T7701 & T7702 the same.
              When powered-up with jumped PD cable, the reads 0V on input pin-pair, and 0V on output pin-pairs.
              • beetle1303
                • Jul 2019
                • 279
                • Singapore
                #27
                I have earlier measures the capacitance of these caps, and all are on-par with the stated values. But I dont have the meter for ESR values.
                On powered-up with jumped pins, all these caps measured between 5-13+V, looks quite normal to me.
                What might not be normal is the T7901 - similar to T7701 & T7702, it measures mostly 0V on the input and output pin-pairs.
                What is the correct way to measure transformer in put and output voltages?
                  • 12312
                  • U.S.
                  #28
                  you should be getting voltage on some of those, on hot side you use the negative of one of the big filter caps as ground, so neg. probe on that and pos. probe on what you're checking.
                    • 12312
                    • U.S.
                    #29
                    if you still have no voltage when powered, maybe trace it to where it stops, which seems to be right after the big caps somewhere in that area.
                    • Diah
                      • Feb 2013
                      • 6501
                      power boards are fine...
                      yours problem at MB, didn't send PS_ON... could be the MB tosted / dead or the SW or too the SPI flash.
                      the front LED when it blink its the first boot sequences of the SPI which it didn't complete... try freeze the SPI
                      • beetle1303
                        • Jul 2019
                        • 279
                        • Singapore
                        #31
                        I am not getting any voltages on those 2 transformers. And you're right, after tracing the 400Vdc from the big caps to the component Q7700, and 0v output to the transformer.
                        I tested this transistor:
                        1) Red probe on middle pin:
                        Black probe on either pin - Open
                        2) Black probe on middle pin:
                        Red probe on left pin: 528
                        Red probe on right pin: 732
                        Does it sounds bad or OK?
                        • beetle1303
                          • Jul 2019
                          • 279
                          • Singapore
                          #32
                          yours problem at MB, didn't send PS_ON... could be the MB toasted / dead or the SW or too the SPI flash.
                          I am very convinced MB is completed toasted, since there is any shorts that causing fluctuating voltages like it was initially.
                          But I also curious about whether the BL is working since it has no power to he BL section of the PS.
                          From my precedent replying post - does it looks like BL is not working?
                          Question: What's a SPI ?
                            • 12312
                            • U.S.
                            #33
                            wondering why the backlights didn't come on when powerboard is jumped, sure seems like they should.
                              • 12312
                              • U.S.
                              #34
                              • beetle1303
                                • Jul 2019
                                • 279
                                • Singapore
                                #35
                                There is no power supply to those 2 transformers, because Q7700 is either faulty or not triggered?
                                  • 12312
                                  • U.S.
                                  #36
                                  test q7700 again, put black probe on neg. of big cap and red probe on each leg of that fet.
                                    • 12312
                                    • U.S.
                                    #37
                                    make sure your meter is set to at least 200 if it isn't an auto range meter.
                                      • 12312
                                      • U.S.
                                      #38
                                      what happened? beer break?
                                      • beetle1303
                                        • Jul 2019
                                        • 279
                                        • Singapore
                                        #39
                                        Black probe on big cap negative, red on middle pin of Q7700 - 402VDC
                                        Black probe on big cap negative, red on either pin of Q7700 - 0VDC
                                        Repeated a few times..
                                        How does this Q7700 works?
                                        • Diah
                                          • Feb 2013
                                          • 6501
                                          men... you are really funny... who care on BL if they come on or not when the MB dead.
                                          did you know which pin BL_ON ?? we tested panel 12V. and main 13V are good mean PCB 100% working
                                          what the diffrent if man his legs brocken and you insist to teach him dancing !!!!
                                          • Cemal Odabasioglu
                                            MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                            by Cemal Odabasioglu
                                            I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                            Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                            Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                            Observations...
                                            01-14-2025, 03:54 PM
                                          • triplefour
                                            ONN 100012588 Has fluctuating Voltage on PSU 12v
                                            by triplefour
                                            Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                                            anyway i go to this guys house to look at an ONN 100012588
                                            this is my first time looking at one of these brand of TV's.
                                            TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                                            09-14-2022, 07:41 PM
                                          • beetle1303
                                            Wine Chiller - SMPS issue - fluctuating voltages
                                            by beetle1303
                                            My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                                            Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                                            Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                                            Checking further on the primary side: Incoming line input to bridge...
                                            09-04-2023, 10:33 AM
                                          • koby058
                                            yoga9 3v3 5v fluctuating
                                            by koby058
                                            Hi
                                            board model: NM-D992
                                            type c remains on 5v. when i connect it the 3.3VALW and 5VALW fluctuating. can someone please help understand why?
                                            main power rail voltage 13v
                                            till now i have tried:
                                            measured all coils resistance looks ok
                                            replaced RT6585CGQW to a brand new one
                                            replaced all mosfets for 3.3v regulator and the dual mosfet for 5v regulator
                                            happen both on DC power and on battery
                                            issue remains
                                            video
                                            schematic attached...
                                            08-03-2025, 09:06 AM
                                          • madan1
                                            DALI SUB E-12F class D, fluctuating power rail
                                            by madan1
                                            Good day everyone.
                                            I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                                            The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                                            The normal value of the positive and negative power rails is +/- 43V.
                                            The positive rail stays...
                                            10-15-2025, 10:33 AM
