I have a WD-92840 with an error code 39. Anyone have any idea? The TV is very clean. I was thinking there is an issue with the thermal fuse but could not find it on the service manual.
Mitsubishi Wd-92840 error code 39
Re: Wd-92840
If the tach signal is bad coming from one of the fans it should be a different error code, but I would check them anyway. It might be that the dmd board has a problem and throwing the error. I have not worked on a dlp tv in many years. Common problems were color wheel failure and it is possible the lamp is causing the problem, note the error code 34. It may also be a power supply issue causing the ballast to shut down.Last edited by R_J; 04-05-2022, 06:36 PM.Comment
by CurtissimoHi everyone.
I have a HP Elitebook 850 G8.
Serial: 5CG2324XM0
ProdID 6L8D5EC#ABA
It has a Winbond W25Q256JVEN Chip.
I need to remove BIOS Password.
I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
Attached my dump.
I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
What I did:...-
Channel: BIOS Requests ONLY!
Hi all.i have problem with my alienware 15 r2.basically its keep beeping 4 times at startup-what means there is ram issue.i already tried 10 different ram sticks with different speeds and voltages but nothing helps.tried to flash bios to see if that will help-but no luck.
Ram sockets looks fine as well,cleaned them and carefully inspected
So maybe someone had this problem as well with any of dell laptops and have some ideas what else i can do?
Thanks05-23-2023, 12:48 PM -
by MaalobsHi,
I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
The relevant service manual for the chassis is available here.
The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
When I short the SDM to ground I get the layer-2 error code 53.
The inside of the TV has no damaged components and no swollen capacitors.
In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured... -
by pc1staidHi Guys and Gals,
I have a really strange issue with the above titled Ultrabook.
Quick spec's, i7-6600 with intel HD520 graphics, 8GB DDR-4 RAM, 256GB M.2 SSD, 12" screen, Wifi, Finger print, NFC.
Use of the laptop is out on sites, remoted into a NAS just for files, software installed Win10, Office 2019, Teams, Printer software. Thats it, sledge hammer to crack a walnut.
OK, the issue. 4 days prior to me getting it, just after login, approx 15 secs the laptop will shutdown. Not as in power off/cut, no restart, it goes through the shut down procedure. This is... -
by bohabohawhen upgrading windows 7 to windows 10 i get this error code (title).then to correct the error i have to enable tls 1.1 and tls 1.2 in registry editor. but there I do not find TLS 1.1 and TLS 1.2 instead there is SSL2.0
in REGISTER EDITOR on windows 7 ad can one do to correct the problem?
Error Code 0x80072f8f 20000-
- Loading...
