Samsung Smart TV - No HDMI working
  • angelos
    • Dec 2012
    • 568
    • South Africa
    Hi guys, this is just a general question but if this TV has got 2 HDMI ports and both do not work what could be the problem.
    So If I feed a signal to the HDMI1 and put my TV to that source all I get is a blank screen. I do not get a "no signal" message. If I switch off my DVD player (The source) then I get a message saying no signal.
    Software is up to date (Tried updating it) - Don't know how to back roll the update.
    Also I don't know what to look for in service mode that might have a bearing on this issue.
    Regards
    Angelos
  • jord4231
    • Feb 2022
    • 16
    Re: Samsung Smart TV - No HDMI working
    Possibly not helpful but just because I had a dvd player fail today in a very similar way have you tried a different device on the HDMI inputs? Perhaps a computer or laptop that will detect a display.
    Also check the hdmi cable?
    With out having a look inside the TV I once had one where the tv would show everything on the onscreen display but no HDMI inputs.
    I heated the processor and the inputs came back.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Bad hdmi chip. Lack of voltage to hdmi.
      • angelos
        • Dec 2012
        • 568
        • South Africa
        I have ordered new board already. Just very expensive.
        • angelos
          • Dec 2012
          • 568
          • South Africa
          I have tried different devices, no luck. But yes it would be the main board. So i will order a new one.
          • angelos
            • Dec 2012
            • 568
            • South Africa
            Thanks goes to everyone who responded to help confirm my suspicions!
            Regards
            • grimacelord
              Samsung UN50MU6070FXZA - HDMI Ports Not Working
              by grimacelord
              Hello. Samsung UN50MU6070FXZA here with both HDMI ports non-working. I have already verified multiple sources and multiple cables to ensure it isn't something simple like that as well as resets and software updates.
              I took the mainboard out and gave it a look. Nothing looks bad or burned. All of the HDMI pins are nice, none are broken at their pads either.
              Following the traces, it looks like both HDMI ports trace back to the main CPU which does seem to get hotter than I think it should despite it's (rather poor) heatsink.
              Since the HDMI controller appears...
              11-03-2021, 03:10 PM
              09-07-2024, 05:50 AM
            • DynaxSC
              ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
              by DynaxSC
              I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
              Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
              Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
              The behaviour is also really very strange, i.e.:
              • The disk shows always up in BIOS - so it is recognized, so far so good
              • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
              02-23-2025, 01:33 PM
            • hinisa
              GTX 750 HDMI output not working
              by hinisa
              Hi
              I have an GTX750-FML-1GD5 with a non-working HDMI port and I'd like to figure out what's the cause and if it's easily repairable.
              GPU is working fine. VGA and DVI-D ports are also working just fine. But whatever monitor or TV I plug into the HDMI port, it isn't even recognized, let alone giving a display.
              I took a glance at the HDMI port and couldn't see any obviously broken parts.
              I've also read on various forums that some firmware versions have non-working hdmi, so I flashed dozen or so different VBIOS ROMs that I acquired from techpowerup...
              12-05-2021, 07:58 AM
            • x_orange90_x
              Samsung UA40J5200AK missing Smart features?
              by x_orange90_x
              I picked up this TV a couple days ago and it's SUPPOSED to be a smart tv, however it doesnt have any apps or wifi settings to change. I cannot find this EXACT model, it's actually a slight variant that is turning up this information. This is a UA40J5200AKXZN.
              The interesting thing about this tv is where it was made. It was made in Egypt. The closest information that I can find that could apply to this model is the following website:
              https://www.google.com/url?sa=t&sour...-ua-40j-n5200-...
              10-24-2024, 12:29 PM
